sub wiring?
Old Nov 4, 2005 | 03:16 PM
YellowOne's Avatar
sub wiring?
i have a rockford fosgate RFP4210, its a dual 4 ohm sub and an kenwood kac 7251 amp that supposely push 460w X 1 in ohm. just wonder what would be the best way to wire the sub to amp. thanks
Old Nov 4, 2005 | 04:11 PM
AscendantMax's Avatar
these are your two options:
parallel wiring
series wiring
that amp is only stable at 4 ohms when bridged. so wiring your sub to parallel isn't a good option. but when you wire into a series, your sub won't see much power when you bridge your amp. you could wire each voice coil to each channel. but if you do this, use a rca spliter split either the L or R on the rca coming from the HU, then connect it to your amp. so it'll be something like:
L-----x (not used)
R------ (use y spliter, run to amp L and R input)
this will let the voice coils get the same signal from the amp. easiest way imo is to get a mono amp.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
