how to flash high beams w/out HIDs flashing?
Has anyone re-wired their Max so that if your lights are off and you need to flash your high beams the HIDs do not come on as well? Does this happen to other 5.5 gens? I put my HIDs in my brother's 01 Max for a test fit then put them back in my Max. Did I switch some wires around? Thanks.
u gotta upgrade to a 6th gen. but then you just don't flash people during the day b/c they are your HIDs. also sucks when the alram goes off, flashes HIDs (good for attention, but if accidently pressed)
AUTO still sucks. should simply be OFF>PARK>AUTO>ON
I might rewire if I had a 5.5 to separate HID and halo. but then you would still flash the HIDs on and off excessively when turning off the high beams. so to me that design is worse than factory anyway. much less likely to flash during the day than turning highs on and off at night.
I just want to rewire my fogs to come on with the park lights and not dependent low beams. but I'll wait until my Ext. warranty is up.
Originally Posted by merovi
wait I always leave it in the auto position. I do not have HID's but is this bad? if it is can someone please inform me why?
Originally Posted by UGAd13
So... Has anyone found a way to rewire the lights so that the HIDs do not come on if you have to flash someone when your lights are not already turned on?
Originally Posted by MacAlert
That happens on all 5.5 gens.
I honestly don't recall how I wired them though, but it was with the 2k2-3 harness wired directly into my stock harness...
as you can see...it can be done:
Originally Posted by irish44j
with my 2k2-3 HIDs wired into my 2k-1 harness, my HIDs stay on when I flash the high beams
Originally Posted by MIXXMAX
I think I read someone on here who did this a while back. It takes a whole lot of rewiring and messing with the relays. The lighting system in our Max's are somewhat daisy-chained with so many circuits it's sickening. This rewiring mod is rather difficult and time consuming, unless you have the time and full understanding of doing it. I would rather just leave it alone and accept Nissan's crappy design, than messing up my whole electrical system trying to work around it.
Originally Posted by BewstAdd1ct
+1 for auto-off-park-on
link plz
link plz
Reference: http://www.divernet.com/equipment/0705divertests.shtml
Also: http://forums.maxima.org/showthread....4&page=1&pp=40
I think HIDS don't like being turned on and off when they aren't properly warmed up or cooled down. For instance, they don't like being flickered on a off... but i can't imagine it being bad to normally turn them on and off for regular driving.
yes, in understand that turning on HIDs before they have cooled from being turned on isnt good for them, i was hoping you had something technical. the first is a divers website, and the other a discussion on the board. dont you have anything official?
furthermore...
furthermore...
Originally Posted by BlackMaxx
Studies show more than 3 on/off intervals in a row reduce the life of the burners...
The research only indicates that continuous on/off switches "seem" to reduce life on data sheets.
This means it is not a major reduction, so 12.5 years might be 10, and 12.5 is average so it may last that long anyway.
Apr 16, 2020 05:15 AM
