Heat- Can You Use Recirculaton?
Hi guys, I know this question may sound like a newbie, but can you use the recirculation button you use with the AC to get it going quick with the heat, or will it cause problems?
Originally Posted by wannaboostbad
the only times u CANNOT use recirc is when u got the defroster and or defrost/feet button pushed it like......cancels the recirc and takes in outside air.
The system works best with fresh air. If you rec. you will build up moisture inside the car causing your windows to fog up. Use the fresh setting and blow a good amout of fresh, outside air through the system and your windows stay clear during winter months. Above freezing, use the A/C on cold rainy days to keep your windows clear.
That information can be found in your owners manual.
