How often should the coil packs be replaced?
Coil packs are SUPPOSED to last a lifetime, however, as you've probably grown to know, that is not the case with Maximas. The OEM coils are Hanshins, but a better replacement seems to be Mitsubishis..
Please Help!
I have a 1996 Nissan Maxima and the engine started running really choppy and would almost stall out. I had a diagnostic run the car and it said I had a bad Speed Sensor and bad Knock Sensor. I replaced both parts and the engine is still running choppy. I did a self diagnostic test and it’s giving me error codes:
1008 - EVAP canister purge volume control valve
1302 - MAP/BARO SW Solenoid/Valve (What is this?)
Has anyone experienced this? Could this just be bad ignition coils?
Thanks for the help,
Scott
Scott
Originally Posted by gtmuggs
so your sayin i can use Mitsu coil packs and where would i get them from is there a specific part number i need or are they pretty much the same?
any idea where to order from ?
Originally Posted by edwardh1
which side of the engine is right and left
the car front vs car firewall???????
What? im not sure i understand, its a transverse mount so its front and back, not right and left.
vingodine
45
May 21, 2016 12:46 PM
kenc15
Sep 25, 2015 06:38 AM
