Anybody know what the name of this part is??
I have been looking through manuals all day trying to strip down my front end and this bar that goes across the front of the radiator, in front of it, which sits about the level of the middle of the radiator, is all mangled..
This bar looks just like the radiator support bar (top), but it sits lower and is in between the radiator and bumper, I believe it is on top of the bumper reinforcement and bolts on with one nut on each side just inside the corner lights.. If anyone can help me find this part, and/or order one I would apprecaite it.. thanks
My digi cam broke last night or else I would have a pic...
Do you mean the black one directly above the silver bumper reinforcement in these pics?
http://www.carstalkers.com/gallery/t...ls.php?album=4
Yes, that would be the one.... there are also a couple pics on the third page of my car domain.. look just like the ones posted above.. whats the name of that piece or where do i get another..??
Also, the part that goes down vertically from the hood latch and mounts at the bottom with one bolt//
thanks for the help..
Radiator or radiator support? Radiator support can't be replaced without either a drill to drill out the spot welds or a torch/plasma cutter and something with which to weld the new support back in place.
The radiator itself, it's pretty much easy to replace (more so than the support, anyway).
As far as the black support there, get the part number off of it (I believe it's on the left hand side, stamped in the metal), and see if these guys have it listed: http://www.trademotion.com/partlocat...49&catalogid=0
thanks for your help... I think that the radiator support is fine.. The radiator itself is what I was referring to// Do I replace the radiator attached to the fans?? or the one that is bolted down under the radiator support? or both... I was not sure if radiators were two seperate pieces or if one is something else.. thanks again
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
