New SFR 350z Intake Manifold
http://www.my350z.com/forum/showthread.php?t=158576
Kinda reminds you of the first generation Yamaha SHO 3.0L IM's, huh?
Personally I would put the TB at the front already. Everyone and their grandmother is putting out IM's with nasty bends at the back just because the stocker is located there. Oh well. It looks good, gotta give all the aftermarket Z manifolds that.
I don't see how this design would help at all...
But at least the G & Z guys have shops making new parts for them and us Maxima folk get stuck with mostly left overs.
I think all these guys are underating the stock G/Z manifold. If I had a Z I'd just buy a spacer and call it a day.
But I'm sure it still makes more power than our intakes.
Piece of cake to make any made-from-scratch G/Z manifolds fit our cars, power's the real criteria. At least on a FWD you wouldn't have that nasty TB flange bend, it'd just be a short, straight tube on the side.
As I said, there was a lot of R&D into the OEM 350z manifold and IMO its only flaws are starving the two front cylinders (thanks to the slope, i.e. little hood clearance) and TB location. But I don't think it's impossible to improve upon it.
Horned runners now that's an interesting idea. But the actual runner length of the G/Z manifold isn't *that* short because you have to take into account the lower.
Where did they say 1300$?
Originally Posted by Jime
Geez at $1300 it cost more than my whole engine.
****! I will take two of them suckers.
http://www.speedforceracing.com/prod...y_g35imani.php
1300 bucks? This is getting ridiculous. We're paying for looks. I don't care if it looks like retarded, as long as it actually makes power. They need to start designing all go no show pieces.
Dunno about the high RPM drop off... he said they made the plenum slightly larger than the engine displacement.
BTW Stock one is approx 5L
Thinking I might put on my surgeon's gloves and see what I can do to the stock one, can't see spending $800 let along $1300 for something I can play with myself.
I paid $80 shipped for my spare stock upper+elbow.
Did you do anything to your intake other than remove the butterfly? Thinking I might put on my surgeon's gloves and see what I can do to the stock one, can't see spending $800 let along $1300 for something I can play with myself. I could do a lot of experimenting for that kind of money.
Right now I'm seriously mulling over building a complete Aluminum upper from scratch. I've got a few ideas, mainly to equalize the airflow between all 6 cylinders. I think that's the problem with all the aftermarket manifolds; they're overly complicated. We have inline, round lower ports, should take advantage of this.
All the fastest all motor cars seem to have air horns no matter what the plenum design is.
Also it's possible to 'decide' the peak torque you want with runner length/diameter. Seen several formulas. Just need to make sense of them. A 5000 rpm peak torque would be awesome (where you 'land' around 5k after a shift, where the beef of the powerband is from 5 to 7k).
No matter what the plenum design is, it should equalize air between all the cylinders. And no dead air pockets.
What about making an upper that just a cover? Then make the lower include individual trumpets ala older M5 intake manifold? The upper cover would leave you the option of putting the TB plate almost anywhere.
Here are pics of the new M5 version. It's the older version I was talking about but can't find pics of http://www.germancarfans.com/photos....001/bmw/1.html
I looked at the M3's IM. They have individual TB's but all the best NA intake manifold designs seem to "imitate" ITB's. At least that's the impression I'm getting. So air horns is a must. But you don't need to touch the lower. Machine a flange (not too hard considering the 3.5 has round ports vs oval for the 3.0) and have the horns immediately 'complete' the runners, then plenum, TB...
True, but they appear to have increased the runner length. The may have cancelled each other out, who knows until we see a dyno.
allen
The flange doesn't have to be machined that way. A rectangular 3/8 one would do the job just as well IMO
But I guess it adds to the 'bling factor.
and yes in the 350z IM stock theres air horns in there the new rev up IM has even shorter horns now.
Kris, I remember someone posted pictures of the inside of a stock 350z IM, but that was the 287 HP version. Where did you see pictures of the 300 HP 05+ engine IM?
did you see the MREV mod over at my350z.com? It replaces the plenum on the 300hp engine with one from a 287 hp engine and uses a spacer. It gives huge area under the curve, and sacrifices very little top end.
The stock 350z manifold is not that bad of a design. If I had one, I would add a spacer which gets 90% of the gains of a manifold and looks stock.
Exactly. But that thing is way too huge to fit under our hoods.
By the way, I found a picture that compares the 287 hp to the 300 hp plenum:
The above one is the 287 hp version. Kris was right, still air horn style opening but shorter. Yet the plenum is the same size, so larger chamber/shorter runners. Same angle, same edge shape.
I wouldn't. This car is going to keep its 99% stock appearance till it dies. I am convinced that an IM that gives even better gains than an OEM 350z IM can be made to fit under our hoods.
There is a major flaw in the design of that intake manifold pictured in the first post. On the pic of the Accord V6 pictured later on in the thread there is a cross member at the end of the manifold. This is needed to equalize the air volume across the cylinders. Without it, the air volume can be unequal and cause lean or rich conditions in each cylinder. It can be easily fixed by attaching the two ends together like on the Accord or by making a balance bar to go across the top. An example of the balance bar is on the 300zx manifold.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
