Shifter Stiff when cold
Old Dec 12, 2005 | 08:48 PM
sachmo's Avatar
Just wondering if everyone gets this with their five speeds. When i wiggle it in neutral its like its in a thick almost frozen liquid, prolly transmission fluid of course.
Old Dec 12, 2005 | 08:55 PM
KRRZ350's Avatar
Yup I get that to, it's totally normal. Also, I beleive nissan recommends changing the transaxle fluid at a ridiculous interval, like 30k, that way you only need to change it once and the next time it will get changed when you rebuild the dif. bearings.
Old Dec 12, 2005 | 10:07 PM
sachmo's Avatar
i guess i should take care of that sometime soon i have no idea when the last time the fluid has been changed
Old Dec 12, 2005 | 10:36 PM
DR-Max's Avatar
I have been using the Redline MT90 for my manual tranny. I'm not sure how it holds up in extreme freezing winters but in southern California, it holds up just fine thru our winters.
Old Dec 13, 2005 | 12:47 AM
oTranscendental's Avatar
East coast winters bite.
Old Dec 13, 2005 | 02:01 AM
90stanza's Avatar
its normal just warm your car up and you should be fine
Old Dec 13, 2005 | 03:31 AM
dgeesaman's Avatar
Maintenance Monster
It's fine down to 0F, and I'm sure colder than that too. Fortunately I wouldn't know
Old Dec 13, 2005 | 04:34 AM
Wheelie King's Avatar
I use Redline in my 5 spd. Its held up against the cold just fine and I've seen many days below zero.
Old Dec 13, 2005 | 05:05 AM
maxgtr2000's Avatar
KH3 by popular demand
Switch to synthetic it will take the stiffness out, especially in cold weather.
Old Dec 13, 2005 | 06:15 AM
Ninos_Maxima's Avatar
be the change u want2C
i have redline and it still gets stiff in chicago
Old Dec 13, 2005 | 06:53 AM
MaximaSE96's Avatar
Maxima Owner
my shifter gets stiff too....it was -1F this morning...let the car warm up for like 10 min and take it easy for the first few shifts and u will be ok
Old Dec 13, 2005 | 11:46 AM
sachmo's Avatar
warming the car up does nothing for transmission wise. The engine can be completly warmed up and the shifter is still stiff.
Old Dec 13, 2005 | 11:48 AM
MaximaSE96's Avatar
Maxima Owner
oh contrar mofrar.....maybe its jsut my superhuman strength but my shifter was way stiffer jsut putting it into neutral when starting the car than it was when i actually left 15 min later
Old Dec 13, 2005 | 12:07 PM
dgeesaman's Avatar
Maintenance Monster
Hopefully your transmission doesn't have flakes of metal floating around in there - I've seen shifter rods badly pitted from the shards of metal getting stuck at the shift rod seal. That would certainly make shifting a lot harder.
Dave
Old Dec 13, 2005 | 01:07 PM
KRRZ350's Avatar
The input shaft and all gears on it are still turning around when the engine is running in nuetral so it should make a little difference.
Old Dec 13, 2005 | 01:10 PM
Dooley's Avatar
How many quarts does it take to fill - 5?
Where is a good place to find Redline MT90 online?
Thanks!
Old Dec 13, 2005 | 05:46 PM
Mishmosh's Avatar
4.5 qts.
Pretty normal to feel like rowing butter when it's cold out. Should loosen up when the car heats up.
I like GM Synchromesh fluid myself. Redline MT90 felt too notchy--better after adding some friction modifier but I shouldn't have to do that.
Old Dec 14, 2005 | 07:18 AM
96mAx2fast's Avatar
Redline MT90 is the way to go. Beleive it or not, its your leather that is frozen and preventing it from moving freely side to side.. warm it up, turn the heat up all the way and aim it downwards. It should feel better. As far as the notch shifting, like i said, mt90 is the way to go. Im going for it myself
Old Dec 14, 2005 | 11:01 AM
d00df00d's Avatar
Old enuf to pick his own gears
Or you could PM me or Talkinghorse for a great price (dealer cost) on Amsoil fully synthetic gear oil.
I'm using it and it's treating me very well, even on the coldest PA mornings.
Old Dec 14, 2005 | 11:32 AM
ewuzh's Avatar
Get MT90. I just switched and everything is butter smooth .
Old Dec 18, 2005 | 09:02 AM
KRRZ350's Avatar
I can pop my broken shifter trim off and back on in about 3 seconds flat (makes a good hiding spot!) and it's pretty cold outside right now, so I'm going to go put that theory to the test.
Old Dec 18, 2005 | 10:13 AM
Mishmosh's Avatar
No way is that the problem. I wouldn't even bother...
Old Dec 19, 2005 | 08:10 AM
KRRZ350's Avatar
You don't think that's the same thing I said?? I was like, jeeze, this guy is a complete moron, only I wanted to wait till after I checked that out for myself. No lie, the shifter is deffinitly way looser, side to side anyways, maybe not going into gear, but side to side on a cold morning it's not stiff at all when you pop the trim off and hold the leather over the ****. Give it a try before you bash either of us.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
Fbana41
Aug 29, 2016 12:18 PM
atriuum
Sep 28, 2015 01:19 PM
