changing coil packs, how?
There's a link in the How To FAQ's regarding changing spark plugs. The procedure should be quite similar for changing the coil packs. If you follow most of what's said here, you should be fine. http://www.vqpower.com/v2/modules.ph...howpage&pid=33
Originally Posted by Dubbya
Just be careful with the coil packs. I broke one of mine removing it. Try not to bend them.
Originally Posted by themills
I cant imagine breaking a coil pack
Originally Posted by NmexMAX
Broke the boot from the main portion. ..
Car runs perfect, so I can't imagine we didn't do a good job of getting everything back in place even though it came off
when should coil packs be changed? i just bought my car at 132k miles on it, that dude didn't change spark plugs or coil packs, i just replaced all the spark plugs, which i might say are not some cheap shiet spark plugs for this specific engine, actually quality stuff if you buy what's required and not some various shiet, should i replace all the coil packs also?
Nice thread. I think I need to replace one (or more) of my coil packs. The car seems to give a slight sputter at random when idling. I replaced one coil pack 2 yrs ago when I bought my 99 Maxima. It was one of the 3 front ones and was easy. I'm afraid the rear ones will be a lot more difficult. Where do you suggest I get the coil packs? Should I get one and swap it out with existing ones till I find the problem or just replace them all? How much are they? Any pointers on the rear ones?
Thanks,
Kierslee
Thanks,
Kierslee
Have you considered the possibility that it may not be coil packs at all?
I haven't considered alternatives just because I don't know what else the problem might be. I'm not getting a warning light to check the code or anything. Do you have any suggestions for other things I might look for?
Kierlsee
Kierlsee
Kierlsee
Kierlsee
Originally Posted by Tatanko
It has to be something fuel or spark related, so obviously you can't rule out coil packs entirely...in fact, check them, by all means.
This started happening in September. I had a tune up done, which I understand to have included plugs, wires, etc. The tune up didn't seem to make it any better or worse.
what wires? i thought the talk is about coil packs... on this engine, the coil pack replaces the regular wires other cars have, and along with the other dude that had a slight stutter, i got that too, it was real bad until i changed the knock sensor, it got better, then i found out that the last dude didnt change the original spark plugs so i did that too, then it comes out that one coil pack is bad and needs to be replaced, by having bad coil packs or old spark plugs and being late on tune ups, it makes the engine misfire, so i narrowed down to this problem from an assortment of problems, this sucks but this is a damn good car tho
Kierslee
I have exactly the same symptoms on my 99 Maxima. I also suspect the coils since I have recently changed the spark plugs. I am going to change all 6 coils. You can choose Hanshin or Mitsubishi coils at http://www.nissanpartsonline.net/.
vk
vk
changed the coil pack today... it was the rear bank, damn thing was covered in like this yellow smelly powder type substances, disgusting, but cars runs real smooth now, idles real quiet, accelerates smoother, overall big improvement in my opinion.
Originally Posted by vkarasik
Kierslee
vk
vk
depone
How did you figure out which one was bad?
vk
vk
to test them unplug each one one at a time....if the one u unplgugged affects the idle its the bad one if u have one unplugged and u start the car and it ran like it did originally thats ur bad one....or u can have them all pluged in start the car and unplug one at at a time while the car is running to determine which effects idle...jsut wear rubber gloves cause its a pretty intese charge going throug them....i but i would keep starting and shutting off the car in between unplugging and plugging in
OR.....you can loosen the screws, and leave them in their, and just tug the coilpacks out, and the screws will remain in the holes of the coilpacks and will just come right out. Do it slowly so u dont loose them.
As I look for the parts it seems there is a "right hand" and "left hand" coil pack. How do I know which I need?
Originally Posted by ssm0003
The fronts or Left side ones are shaped differently than the back ones. My coil pak prob didn't show up until the car was warmed up nice and hot - after about 30 minutes of running.
didnt show up? where did they go? magically disappear and then appear after the car is warmed up? are you serious? the fronts are different than the back, when you buy the parts the front ones are # C0001 i think and the rear is # C0002, slight difference but its there so dont forget, get the parts from auto zone, not pep boys, pep boys designates them as left or right, fu*king morons, its front or back, and they offer mitsubishi coil packs or hanshin(nissan oem) coil packs, why the fu*k would anyone buy ****ty mitsubishi anything and put it on this beautiful car, it has to be the dumbest thing you can do to this car besides put regular gas in it
Yesterday on the way to work, the car really felt rough on idle and started misfiring on acceleration. The SEL light started blinking and then came fully on. I took the car to my mechanic. He said the code specified that there was a misfire on cylinder #3. I told him to change the #3 coil. He did but he said the car was still misfiring. I said lets change the remaining 5 ignition coils. Now the car runs like new. It has not felt like this in at least a year. No misfires and really smooth acceleration.
vk
vk
