Hlsd?
Old Feb 9, 2006 | 09:57 PM
rchun08's Avatar
Hlsd?
how do you know if your car is equipped with HLSD? I have a 2002 Se maxima..is it written under the hood or somewhere on the car.
might be a horrible question, but can you add it too?
Old Feb 9, 2006 | 10:13 PM
steven88's Avatar
Need A Light?
yes you can add HLSD if your car has an open diff
pop open your hood...there is a silver metal plate on your firewall...it will say ENGINE VQ35DE....then below it is the transmission code....at the end of the code, if it says A, then its an open diff....if it says H then its a locking diff (HLSD)
Old Feb 9, 2006 | 10:17 PM
Mass_Media's Avatar
Mass_Media™
Another way of checking without poping the hood is looking at your pedals since your car is a 6spd. If they look like this:
then you have HLSD. If they look different then you don't.
Old Feb 10, 2006 | 12:34 AM
rchun08's Avatar
ok my petals do look like that...I was thinking of changing it to a aftermarket..any popular ones for our maximas
Old Feb 10, 2006 | 01:14 AM
steven88's Avatar
Need A Light?
Sparco pedals...i have them and they work great...heel toe is a breeze.....also made out of high quality materials...rubber inserts wont allow your feet to slip during rainy season
Old Feb 10, 2006 | 06:26 AM
boondoxmax's Avatar
My car has HLSD and the best way is to pop the hood and look at the transaxle code. RS6f51H
Old Feb 10, 2006 | 06:47 AM
Jasovanni's Avatar
Ok, I've heard mixed reviews on this, but was HLSD an option on the 00, 01 or not, and would it be found in the same manner?
J
Old Feb 10, 2006 | 07:35 AM
boondoxmax's Avatar
only option on 02-03 only. I think the 01 AE had LSD as standard equipment on 5 speeds. And i think its found in the same manner, under the hood
Old Feb 10, 2006 | 09:12 AM
Belteshazzar's Avatar
How about the RE4F's(auto)?
I just assumed I had it since I always get two stripes and not one.
But I don't have an H or A in the code.
Old Feb 10, 2006 | 10:50 AM
Puppetmaster's Avatar
That's right, and I believe the 5th Gen VLSD transaxle code ends in "V" and open still ends in "A".
Old Feb 10, 2006 | 10:55 AM
That depends.... some people without HLSD buy those OEM pedals and install em, so if the car has been bought used, I'd still say to check the transaxle code or call Nissan with the VIN to check what options it came out of the factory with.
That being said, Mass Media, have you ever jacked the front up and spun one wheel? On HLSD equipped cars, when you spin on wheel, the other is supposed to spin in the opposite direction. I have a transaxle code ending in "H" and I called Nissan to verify that I have HLSD but don't recall mine ever doing that when I spin the wheels.
Old Feb 10, 2006 | 11:14 AM
boondoxmax's Avatar
Auto don't have HLSD. Some have traction control......
Old Feb 10, 2006 | 06:26 PM
Mass_Media's Avatar
Mass_Media™
ummm....I have never tried doing that I might try that next time i have the car jacked up. I do know that i have HLSD, for 1 this snow season i haven't gotten stuck (did with my gold car)
2 In my gold car when i pulled out of my parking lot i could turn the wheel to the right, floor it and smoke my passenger side up. Now when i try it both tires smoke up, and my whole front end kind of slides.
Old Feb 10, 2006 | 11:19 PM
steven88's Avatar
Need A Light?
have you tried looking under your engine bay?
it's highly unlikely that someone would swap the firewall plate...
Old Feb 11, 2006 | 12:49 AM
Mass_Media's Avatar
Mass_Media™
No then if im wrong i would have another reason to sell my car
Old Feb 11, 2006 | 07:46 AM
History quiz, how about 3rd gens?
I seem to remember my '94 SE automatic would walk sideways instead of burning up just one tire.
Old Feb 11, 2006 | 09:17 AM
abradic's Avatar
Maybe a dumb question, but since I don't know, I have to ask! Does the HLSD eliminate that nasty wheel hop?
Old Feb 11, 2006 | 10:16 AM
hmmmmmm
wheels hop while they're spinning.
a device that reduces wheel spin...
YES! I believe it could indirectly help.
Stiffer springs and/or motor mounts might help a bit too
Old Feb 11, 2006 | 10:43 AM
Mass_Media's Avatar
Mass_Media™
No you'll still have wheel hop
Old Feb 11, 2006 | 03:41 PM
Derrick2k2SE's Avatar
Energy suspension solid motor mounts will help a lot with wheel hop.
Old Feb 11, 2006 | 03:43 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Great thread, this has not been asked a million times.
Would read again, 0/10
Old Feb 11, 2006 | 11:38 PM
rbrown81's Avatar
But why is teh Rum gone?
I cant heel toe... my feet are too big :
Stupid size 16's
Old Feb 12, 2006 | 07:18 AM
TheBigDu's Avatar
Lol. Well placed...
Old Feb 12, 2006 | 11:17 AM
Gjohnson's Avatar
My old 94 SE had limited slip.
Old Mar 7, 2006 | 10:08 AM
I was wrong here ^^, so I'm clarifying this for the benefit of everyone else as well:
Originally Posted by SR20DEN
Also, as I have mentioned before, you cannot confirm you have a helical if your car is up on a lift. Both wheels will not be locked to each other and will each spin freely or opposite each other. The helical only works when torque is applied to the ring gear itself.
http://forums.maxima.org/showpost.ph...8&postcount=22
Old Mar 7, 2006 | 11:45 AM
Hoooper
glad you did. its the opposite though, on cars with locked differentials, spinning one tire in the air will make the other tire spin the same direction.
Old Mar 7, 2006 | 11:52 AM
Yeah, I mean regardless, I just wanted to clear up the myth that putting the front wheels in the air and spinning them can tell you whether it has HLSD or not. In the case of the 5.5 HLSD, it doesn't. I was a little concerned when mine didn't move either way while spinning one tire, which is what led me to dig deeper. My transaxle code and VIN both tell me that I have HLSD, but I just wanted to make sure.
Old Mar 7, 2006 | 02:07 PM
Hoooper
what your transaxle code? the actual #'s. gettin a new trans and want to see if its HLSD
Old Mar 7, 2006 | 02:15 PM
Same as in the link I posted above. It starts in "R" and ends in "H".
Old Mar 7, 2006 | 03:10 PM
Hoooper
ooo, sorry i was thinkin you meant the code stamped onto the transaxle.
Old Mar 7, 2006 | 08:01 PM
Yeah, that is the code stamped on the plate on the firewall, I doubt its on the differential itself.
Old Mar 7, 2006 | 08:04 PM
steven88's Avatar
Need A Light?
will a viscous unit spin in the same direction if its in the air?
Old Mar 7, 2006 | 08:30 PM
Hoooper
it should. the difference (i think) between viscous and helical is the actual gear type. helical gears are slant cut for more surface area and to be stronger just like a reverse gear and i guess viscous is different.
Max139617
Oct 19, 2016 11:34 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
I<3 A32's
Sep 10, 2015 11:07 AM
homeyclaus
Sep 3, 2015 06:15 PM
