225/55/16 vs 225/50/16...Need PICS/comments ASAP
I have a 98 se and have im planning on keeping the same rims, i'm planning on buying the dunlop sp5000s and want to know which size looks better, i have read through the comments under the search function but have yet to see a picture of either of the two above mentioned sizes, i am not lowering my car anytime soon so will the 225/55/16 fill in the gap a little and look better then the 50 series...PICS/input please!!!inspection is up in 15 days so i need to know soon..thanks
yea...the looks difference will be slight
Originally posted by Sarah99GXE
Honestly I went from 65's to 55's and there is hardly any difference, at least none that I see. I don't think going from 55's to 50's is going to be very noticeable. As it is, our car's already look like 4X4's stock
Re: yea...the looks difference will be slight
Originally posted by NYCe MaXiMa
But you'll throw off your speedometer, it will not read the correct speed also the odometer will be affected as well...
http://www.miata.net/garage/tirecalc.html
You can go here and put in your tire sizes and it'll calculate out the difference for you. I had 15" SE rims with 215/60's on 'em, then got 16" rims and got the 225/50's. The speedometer reading difference is very miniscule, unnoticeable. The handling is much better, and will be much better with the 50's compared to the 55's (the sidewalls on the 50's are much thicker/stiffer than that of the 55's - 55's are like 60's and 65's). The 55's will 'fill' the gap a little better but as soon as you get used to looking at the 50's, you're gonna be looking at 225/55's like they are balloons...
BTW, there is a much bigger selection of tires for the 225/50R16 size as well. I have Potenza RE730's which are faboo...
Originally posted by gtr_rider
"speedometer reading with non-stock tire is 2.486% too fast"
and that means?????
and that means?????
Go with 50 series IMO. I run 235/45 series for street and bought 225/55 series for auto-x. The 55's do look like balloons and don't grip anywhere near the 235/45's.
Again, lots more choices in the 225/50 because that was a common stang size and others.
Moving from 205/65/15 to either won't change spedo by more than 2mph.
My GLE came with 205-65-15s and I now have 225-50-16s. I've testes my speedo error with the little radar trailers that you pass that display your speed. It varies linearly with speed. At indicated 45mph I was actually going 43mph. and at 75mph I was actually going 71mph, so I'd say 100 is off by more than 5. -just my findings. The nice thing is that the error is in your favor if you get pulled over/. (Meaning your ticket will be smaller than you expect)
maxfever1987
Nov 19, 2016 08:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
