Why a CCW Straight Discharge Blower?
Old Feb 14, 2006 | 10:18 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I was looking at t-trim blowers online and was thinking. Are the mounting points of the blower opposite or just the scroll?
Old Feb 15, 2006 | 06:56 AM
Ninos_Maxima's Avatar
be the change u want2C
from what ive read i think the mounting is different, and the blower points in a different direction for any other direction discharge
edit*** if you wanna use a different blower
this is the best blower that would fit V-7 JT-Trim (ccw, and straight discharge)
http://forums.maxima.org/showthread.php?t=454681
Old Feb 15, 2006 | 07:12 AM
slimer's Avatar
I was wondering for the mounting position. I might want to do a projector retrofit and currently don't have enough room with how deep the cefiro's go.
Old Feb 15, 2006 | 07:44 AM
matty's Avatar
Steve,
The back plate on the every Vortech blower is the same. Mounting is not a problem. The curved discharge will be a problem though. It will put the air somewhere around the fender well and will most likely require a pipe across the front of the car like Stephanmax did. It will require you to run piping down and around and up. You may need to measure and make sure the actual "scroll curved part" does not go farther than needed. There really isnt that much room there.
-matt
Old Feb 15, 2006 | 07:51 AM
slimer's Avatar
Matt, I don't have a problem with the straight discharge. The problem is the ccw? I want it to go out the top of the motor.
Old Feb 15, 2006 | 07:58 AM
matty's Avatar
Steve,
Impossible. If you look at any convention clockwise vortech blowers, its totally backwards.
Maybe I'm not understanding what you want to do
-matt
Old Feb 15, 2006 | 11:27 AM
slimer's Avatar
Have the oulet on top facing towards the top of the motor. I probably wouldn't do it anyway, but for those that are looking for blowers, a discussion like this might be useful.
Old Feb 15, 2006 | 07:41 PM
i know this may sound a little unconventional, why not try cutting the curved section off the blower making it straight?
James92SE
142
Jan 2, 2024 09:23 AM
knight_yyz
Nov 1, 2015 01:34 PM
Turbonut
46
Oct 21, 2015 08:28 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
