Solinoid Valve Assy.
Old Feb 15, 2006 | 02:53 AM
Italiano's Avatar
SWIFT_Navigator
auto tranny, im having slipping problems with my tranny and found that a TSB that tells me to repace the Solinoid valve assembly. where can i find this part? i searched around so please dont get on my butt for not looking hard enough. i posted in the classifieds WTB the part but for some reason i doubt ill get an offer from anyone. looked at sites that sell OEM max parts as well but came up with no luck. i know this is cheaper to do myself rather than bringing it to nissan, so if i can just find the part im all set.
Old Feb 15, 2006 | 03:12 AM
SEmy2K2go's Avatar
Go BUCKS!!!
What about getting the specific part number from Nissan, then trying to locate one with the part number itself? The TSB doesn't list the parts needed?
Old Feb 15, 2006 | 11:41 AM
kcowden's Avatar
It says to first solder the grounding connection where the wire meets the grounding connector. I think that if that doesn't work then replace. I'm sure the first is the easiest and cheapest.
Old Feb 15, 2006 | 09:10 PM
Italiano's Avatar
SWIFT_Navigator
it gives the part number i just have no clue where to be searching for a part like this is all. or is the dealer my only option? forgive me for not knowing where to search, i did on some oem nissan websites and came up with nothing.
the part number for it was: 31940-85X03
Old Feb 15, 2006 | 09:18 PM
GimmeTorq's Avatar
Search by OEM part and enter the part number... New part number is 3194085X04
http://www.trademotion.com/partlocat...gOEM&siteid=49
$288.94... Ouch!
Old Feb 15, 2006 | 09:20 PM
Hoooper
what?!?!?!?!
Old Feb 16, 2006 | 07:20 AM
vsamoylov
my buddy is selling his in the for sale forum. it has about 7k on it. he wants $200 shipped for everything.
Old Feb 16, 2006 | 07:59 AM
whazzzzuup's Avatar
I have 2 solenoid packs for sale. Here is the thread:
http://forums.maxima.org/showthread.php?t=454749
Old Feb 16, 2006 | 11:24 AM
kcowden's Avatar
Originally Posted by Hoooper
what?!?!?!?!
Tough to explain without a picture. Your VB solenoids are grounded to the tranny via a grounding wire. The TSB states that sometimes that the grounding wire connection is loose. The fix is to solder it. If you can look at the TSB, it explaines it better.
Old Feb 16, 2006 | 02:15 PM
Italiano's Avatar
SWIFT_Navigator
what year is it, or does that even matter for any maxima? id assume id need a 2000 solinoid valve assembly.. maybe 02/03 would work too?
would this part work for a 2000? since i see yours is 02/03, so the part is as well. or does it not make a difference? and you said 'solenoid pack', im assuming thats the part im talking about (solinoid valve assy?). if it all works out i may be very interested in the one with 7 miles since its brand new.
i will read it in detail to see what your talking about, dont remember reading that in the TSB i read though.
Old Feb 16, 2006 | 02:24 PM
vsamoylov
2k-2k1 are different from 2k2-2k3.
Old Feb 16, 2006 | 03:56 PM
Italiano's Avatar
SWIFT_Navigator
so your buddy has a 00/01 part correct? because the other ones wazzzup offered were 02 i believe.
Old Feb 16, 2006 | 04:22 PM
vsamoylov
my buddy wazzzup has a 2k2-2k3
my other buddy has a 2k-2k1 for sale
Old Feb 16, 2006 | 05:14 PM
whazzzzuup's Avatar
If you take a look at the top solenoid, they are talking about soldering the crimp in the location where the red wire makes contact with the grounding bolt. This ensures a better ground.
Old Feb 16, 2006 | 05:18 PM
upstatemax's Avatar
I guess I will be the first to ask the obvious question...
How old is your tranny fluid?
Mine started to slip again and it is due for a change. Your best bet is to have Nissan swap the fluid if it old because you need to suck out all the old fluid. Or if you dont want to drop the money on that there is a how-to on it.
Old Feb 16, 2006 | 08:13 PM
Italiano's Avatar
SWIFT_Navigator
you have a PM
the training fluid is not old.. and its definitely not that, but thanks.
Old Feb 17, 2006 | 07:43 AM
upstatemax's Avatar
How old is it? and how long has it been slipping? A slipping tranny can cook your tranny fluid pretty quick. In one month when my tranny started to slip, my fluid whent from fine and looking nomal --> burnt as hell and toast.
I would look into your TCM, thats what was causing the slipping in my 2000 auto.
Once my TCM was fixed and new fluid put it, it was perfect. Till now, but it needs new fluid, its time....
Old Feb 17, 2006 | 09:21 AM
Love_00_Max's Avatar
Pointer to the TSB (though not of good quality PDF file).
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf
whazzzzuup : Can step 7 be skipped to replace the soleniod valve assembly? Reading thro the TSB the assembly itself is held (5 solenoids) with bolts, is there a necessity to remove the entire assembly as seen in your picture. Or it is a big
Old Feb 17, 2006 | 03:59 PM
whazzzzuup's Avatar
You can take the solenoid packs off without removing the VB, but I strongly recommend against it. It is faster if you just take the VB out and remove the SP afterwards. Manuvering the wrench within that confined space is difficult.
Old Feb 17, 2006 | 06:48 PM
Italiano's Avatar
SWIFT_Navigator
I PM'd you about buying this from your friend or to forward it to him and have gotten no response..
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
Gingerheadman
Oct 1, 2015 05:11 PM
tardrex
Sep 11, 2015 07:35 PM
