Engine cuts out and stalls sometimes
Old Jun 10, 2001 | 08:34 AM
1FasMax
My 92 SE 5 speed has a problem where sometimes when its idleing it just shuts off, but more the problem is ill be taking off in 1st or 2nd gear and it will suddenly completely cut out for a second or 2 and then go right back to normal, when it does this, If i let go of the gas and hit the gas again, its fine, but when it does this its NOT a hesitation, it COMPLETELY looses all power, then comes right back to normal......on/off affect....any ideas??
Old Jun 10, 2001 | 02:40 PM
ninezero's Avatar
there are a lot possible causes of the problem like
low compression,weak sparks.air flow meter.a.a.c.valve etc.
first you can try this : disconect the exhaust gas sensor
go drive and when ok replace it.
Old Jun 26, 2001 | 07:31 PM
maximum810's Avatar
stalling and cutting...
I've had that prob many times in my 93se. I changed the fuel filter, and it hasn't acted up since.
Old Jun 26, 2001 | 07:42 PM
dmontzsta's Avatar
Ford Only.
WOW! This has happened to me and I replaced so much crap.Spark Plugs,All new coils $500,Fuel Filter...etc The dealer just kept telling me all this crap was wrong.I finally took my car to a gas station and they told me it was the Catalyc Converter.
Old Jun 28, 2001 | 01:04 AM
Mr. Nismo's Avatar
Uh ho! Another one bites the dust!! Hopefully not, but this happened to me and it was my Air Flow Meter Sensor. The dealer fixed it and it cost me right around.....$500!
Old Jun 28, 2001 | 06:11 AM
maximum810's Avatar
those damn dealerships...
They'll never let you leave unless you spend more than $300 from them.
shilov
Feb 19, 2024 09:40 PM
97_GXE
Sep 15, 2015 06:47 AM
