Injectors
Old Feb 21, 2006 | 02:14 PM
JClaw's Avatar
Injectors
Is there some sort of online calculator to see which injectors max out at what power output? For example what do 335cc's max out at?
Old Feb 21, 2006 | 02:29 PM
Chief Brody's Avatar
www.stealth316.com has one in the technical section. The RC injector homesite does as well I believe.
Old Feb 21, 2006 | 02:36 PM
Larrio's Avatar
The Definitive AE Master
Its just a guideline and varies a little depending on other factors.
Horsepower x B.S.F.C (IIRC, estimated at 0.5 for N/A applications)
divided by
# of Injectors x 0.80 (80% duty cycle)
http://www.rceng.com/technical.htm
remember the cc to min conversion by multiplying 10.50 to the result for cc/min
If i'm doing this correctly....
335cc's converted to lbs/hr = 31.90 (335 divided by 10.5)
Y horsepower (x) 0.5 divided by 4.80 (6 x 0.80) = 31.90
0.5Y divided by 4.80 = 31.90
0.5Y = 153.12 (31.9 x 4.8)
Y= 306.24 hp (153.12 divided by 0.5)
Old Feb 21, 2006 | 03:03 PM
JClaw's Avatar
Weird... I would have expected more than 30x hp considering Z guys run near 300whp n/a on stock injectors
Old Feb 21, 2006 | 04:52 PM
diymaximakid's Avatar
there arent that many 300whp z's that i could find.from my understanding its very hard for them. (with jus bolt-ons and stock internals)
Old Feb 21, 2006 | 05:18 PM
JClaw's Avatar
Regardless, the ones that get there are still running stock injectors (335cc), making maybe 350 HP at the crank.
Old Feb 21, 2006 | 05:21 PM
Are they raising fuel rail pressure with an FMU? Inputting different fuel pressures will yeild different HPs ceilings.
Old Feb 21, 2006 | 05:23 PM
JClaw's Avatar
I'm almost certain they are using stock 3.5 Bar fuel pressure... I doubt anybody would want to raise it any higher.
Old Feb 21, 2006 | 05:29 PM
95turbo gxe's Avatar
what do you mean their are not many. I made 241whp and 340wtp on 259cc at 90% duty cycle. And you can make up to about 450whp on stock internals with a good tune but not stock injectors for sure
Old Feb 21, 2006 | 07:28 PM
Larrio's Avatar
The calculation doesn't take into effect fuel pressure and other variables such as compression ratio, timing, etc
Old Feb 21, 2006 | 07:39 PM
So does anyone have a good guess what 370cc injectors max out at?
Old Feb 22, 2006 | 08:06 AM
Larrio's Avatar
jdmmax with SC had 370cc injectors and was maxing out at around 250-270 whp because his MAF was maxing out. He's now changed to a 300zx MAF but hasn't dynoed since.
You could probably try snooping around here and the dyno forum to read up on different setups. A lot of boosted 4th gens are using the 370cc injectors
I think a safe assumption with the calculation above would be around 300 whp. The BSFC changes with boosted applications
Old Feb 22, 2006 | 09:58 AM
there aren't that many 350z's n/a pushing over 300whp.atleast I couldnt find them.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
