**HELP** Winding noise when i accelerate
For about a week now, my car has been makeing a winding noise when ever i accelerate. It kinda sounds like i have a supper charger in my car. lol It only makes the noise when i am accelerating. When i let off the gas or put the car in neutral, the noise stops. The winding noise goes through all 5 of my gears but its very faint in 5th gear. Its most noticable when in my lower gears. I am thinking it could be my idle bearing or my engine mounts. What do yall think??
Hey I had a similar problem too. Stil havn't figured it out yet (basically its been too cold sitting outside in the snow to try and find the problem right now lol). I was told to take a look and wait till it got warmer to see if it continued. Anyways... I did post a thread before so check here for some more info: http://forums.maxima.org/showthread.php?t=456912. Hope it helps!
Originally Posted by maxima_kenny96
this may sound stupid as hell...but do you have your IPOD on when it happens??
i popped the hood and listened while by brother hit the gas and i couldnt get to noise to happen. It only makes the noise when i am moveing and in gear. I checked to see if my subs or radio were causing the problem so i un pluged the subs and turned the raido off and it still made the noise. It is the same pitch and loundness wheather i have the radio and subs on or off. I dunno what to do know, its makeing me so frustrated. Any one with suggestions???
i had a similar sound on my old 300zx. turns out it was the water pump. it got loose enough to actually break my alternator belt. try to wiggle the pulley... if it moves, theres a chance the bearing is going downhill
Originally Posted by s0ber
sounds like transmission. input shaft bearings or differential carrier bearings?
if he doesnt hear it when its in neutral then why would it be the alt?
same with a wheel bearing, if he pushes in the clutch and it goes away its not the wheel bearing.
so im going back to my its the transmission theory.
Originally Posted by VTECK999
thats what the problem is, get it fixed or you will break down within the next couple weeks.
My car has made this noise for over 2 months. It's been too cold (w/ too much snow) for me to stay under the hood lately. I was told that it may be the cold so if it makes the noise when it gets nice out then check again. I'm just going to the shop for an opinion. They can fix it or I'll do it depending.
But unless you know you alternator could be going, it's not positive that it's just gonna break down.
Im pretty sure its not the transmission because i have been going a week with the noise, and i havent noticed anything thing weird with my car except the noise. If it was the transmission wouldnt it get worse everyday i drive the car? Or wouldnt the niose get louder?
Originally Posted by DragonMaxima
Does this happen when you start driving or only after awhile of driving? (ex. After a drive on the highway)
most likely alternator (if u meant whining noise)...if u got a system in your car you'll either want to get a bigger alternator or a big capacitor. Any car repair shop should be able to test your alternator to see if its good or dieing
Originally Posted by Progress
It's your tranny bearings. I had the same problem with my 5spd and had the bearing kit replaced and that stopped the noise. They were pitted and worn to hell.
GL
GL
I agree with taking the car to check the alternator. Autozone or Advanced Auto will test it for free.
Dave
GL
GL
I know. What im saying is i have this noise too, and ive been trying to find out what the problem is. So has another person who started another thread a while back. Since we both have this noise, and hes stick while im auto, i dont think its the tranny.
They both have the same differentials, so it's still possible they have gear damage.
But until someone takes the car to a mechanic or starts working to narrow down the possibilities, it's anybody's guess.
Dave
Dave
How would we check the alternator. My previous owner said it was already replaced under that recall. So the new one is making noise too? I wouldnt know, since i its always made that high pitched whistle since i had the car at certain rpms @ load.
I'm telling you man, get it checked out soon. That has been the symptom of a bad alternator on every car that I've had. Trust me, and when you start hearing that noise, you TYPICALLY have only a few weeks until it goes. And once it goes, your car WILL break down.
Originally Posted by Cdg2125
No that doesn't mean it's just gonna die.
Go get your alternator checked so you can rule that out, specifically speaking to hockeyboy. The fact that it only happens in gear makes me think it's the bearings. If they're pitted and worn and you continue to thrash the car it can blow a hole through your differential. I hope it isn't your tranny because it's not a cheap repair having had it done myself. GL
Hey man...I got the same problem...the sounds really annoying...compare to having the quiet sound of a stock max....
Did you get your alternator checked out btw?...
Btw...those of you who replaced the alternator...how much did it cost?...labor and the alt itself.
if its been two months, clearly your alternator is not going. and yes, if his alternator is the problem his car will die on him.
Well weigh this out:
1) Go to Autozone and get the alternator tested for FREE. Time = 10min, cost = 0.
2) Wait until the alternator fails. Time = 2hours on the side of the road, plus time required to get the alternator fixed in a hurry. Cost = one new battery ($80) + towing fee ($100, or AAA).
So you're telling me that you're choosing option 2?
Dave
Dave
Hey man...I just had autozone check it out...its not the alternator...or battery...the guy said its most likely the belts thats making the whining sound...so I guess have a mechanic check it...and from what I heard...it aint that hard to replace the belt...I just wish I had the tools and space to do the stuff...but yea....check the belts bro
get a video for every one to see
same thing happened on my 3rd gen
ended up being the alt..
loud whine when driving from a friends house
went through all the gears samething happened
ill probably be able to tell you if you get a video or something
Kyle Cisneros
Kyle Cisneros
