What the hell, sea foam caused an auto trans fluid leak?
Old Mar 8, 2006 | 09:17 PM
RR5's Avatar
RR5
AFT fluid leak
Alright, so on the 5th of March I score a bottle of Sea Foam motor treatment and give it a run. Followed the directions (both on bottle and from the dot org) everything went fine.
Then kicks in my stupid if its still working FINE, why not add a little sea foam (per directions on bottle) to crankcase (oil). So I pour a dash into my engine from the cap on top of the engine. Off I go.
Monday the 6th, in the morning to work while I'm waiting in line on the toll road, my maxima is smoking like I'm some freaking magician going to pull out turbo piping from my trunk. Crap.
So finally, after this is consistently happening, and after confirming YES I have an automatic transmission fluid leak, I bring it to a shop to take a look at the under-body. Possible blown o-ring seal on the torque converter. I have some pretty bad pictures quality wise, but you can see red "dots" which are pools of fluid.
Has this even remotely happened to anyone? Sea Foam or not. Also, how likely is this going to be fixed with just a tear down and replace all internal seals in the trans???
Thank you in advance! PS: I am still forced to drive as is.. I know its bad.
Old Mar 9, 2006 | 12:03 AM
getbigtony's Avatar
uhh.. i dont see how its related.. u poured it into ur crankcase, not ur tranny/transfercase
Old Mar 9, 2006 | 12:05 AM
upstatemax's Avatar
They are in no way connected to each other....
Old Mar 9, 2006 | 12:32 AM
joaquink's Avatar
¿Hablas Español?
Am I to infer that you are blaming SeaFoam for your car's troubles? SeaFoam >>>>> GOD!!
I can't believe you actually think Sea Foam created this problem when the most viable solution is to add more Sea Foam, specifically to your tranny fluid.
Old Mar 9, 2006 | 12:51 AM
upstatemax's Avatar
To really find out what the problem is you will want to pull your back seats and look for the EGR valve.
Once you find it, let us know how it looks.
Old Mar 9, 2006 | 01:36 AM
joaquink's Avatar
¿Hablas Español?
Hay a$$hole, if you're going to give advice, at least make sure it's complete.
RR5, soak the EGR in Sea Foam for 48 hrs. before reinstalling. Just don't get any on the seating surface during the process.
Old Mar 9, 2006 | 01:43 AM
upstatemax's Avatar
Wow, don't go off the deep end. I just forgot that step, and you did not remember that it is a good idea to remove the rear doors when taking out the back seats either!
Old Mar 9, 2006 | 02:37 AM
SoonerFan's Avatar
Cletus
1. remove the tranny and engine
2. soak both in seafoam for 2 weeks
3. (most important) replace the seal that let the seafoam go from your engine to your tranny in the 1st place
4. put everything back together
ps. now can we please stop with the seafoam threads
Old Mar 9, 2006 | 05:39 AM
Progress's Avatar
It's business time.
Don't forget that after you have finished all the aforementioned steps to take your hood off and go through a touchless car wash FTW!
Old Mar 9, 2006 | 05:40 AM
Puppetmaster's Avatar
Did you guys buy the artificial, processed seafoam or just collect your own at the beach?
Old Mar 9, 2006 | 05:50 AM
5thgenfan's Avatar
I soak my seafoan IN seafoam. It gives me like 43 extra hp.
I heart you, seafoam
Old Mar 9, 2006 | 06:32 AM
SoonerFan's Avatar
Cletus
you just made me laugh out loud...and i really needed it. thanks joel
Old Mar 9, 2006 | 06:39 AM
alpinestars™'s Avatar
THIS IS...
Lmao
Old Mar 9, 2006 | 07:25 AM
RR5's Avatar
RR5
Please keep posts on-topic.
Ok now that we have been collectively lowered to a 4th grade education level, I will restate my problem. This is what I do not understand. Perhaps it was the seals time to die and it did so right after I added the sea foam. Yes I know sea foam works wonders on the engine internals, I feel a nice difference everytime I accelerate.
I have had 0 transmission problems or leaks. In short no transmission problems. 24 hours later after pouring in a little sea foam into my crankcase, I blow a seal internally and cause transmission fluid to seep out. WHAT THE HELL?
Old Mar 9, 2006 | 07:36 AM
Progress's Avatar
It's business time.
Alright. This is what you asked.
From what I've heard, NO when it comes to Seafoam. You have a tranny problem. Why don't you get a quote? Your title is misleading from this point on. I know it's hard to take this but it must be purely coincidental.
Old Mar 9, 2006 | 07:43 AM
TXT-1's Avatar
It's one hell of a coincidence, but I have to agree the Seafoam did not mess up your tranny.
Old Mar 9, 2006 | 07:48 AM
SixxOne's Avatar
I am not that smart.
Poor guy is going to do everything you guys said.
Old Mar 9, 2006 | 08:16 AM
RR5's Avatar
RR5
You want to come meet me and see how smart I am.
Old Mar 9, 2006 | 08:18 AM
SoonerFan's Avatar
Cletus
the org standard is a 4th grade level. and this thread didnt take much since it was started at a 4th grade level
Old Mar 9, 2006 | 08:19 AM
SoonerFan's Avatar
Cletus
meeting you will prove how smart you are?
Old Mar 9, 2006 | 08:20 AM
Progress's Avatar
It's business time.
He's probably referring to mister left and mister right. You want some?
Old Mar 9, 2006 | 08:24 AM
RR5's Avatar
RR5
Everyone should know now when something changes on your car, the first thing you are supposed to do is go over anything you changed on the car.
IE: Added an ADDITIVE, changed some setting, switched fuel, switched motor oil and blah blah.
I was only stating what I did to the car, then what happened.
SoonerFan's Avatar
Cletus
cause that proves intellect
Old Mar 9, 2006 | 08:26 AM
SoonerFan's Avatar
Cletus
you go over what you changed then discount anything that you know didnt have an effect.
i have a flat tire...
a. the last thing i did was change my taillight bulb
b. the thing before that was i filled up with gas
c. maybe it was the nail i drove over
Old Mar 9, 2006 | 08:28 AM
Progress's Avatar
It's business time.
He didn't end his "question" with a "?" so possibly he was commanding or telling him. Perhaps it was a form of internet hypnosis or mind control. Like, you want to send me your HIDs.
Old Mar 9, 2006 | 08:31 AM
SoonerFan's Avatar
Cletus
my HIDs will be sent to you tomorrow sir. anything else?
Old Mar 9, 2006 | 08:35 AM
Jedi mind trick FTW.
THIS IS...
Progress, I love your factitious attitude. Just like me.
Old Mar 9, 2006 | 08:38 AM
Progress's Avatar
It's business time.
Noodz of your better half will suffice.
Old Mar 9, 2006 | 08:40 AM
Progress's Avatar
It's business time.
Do you wanna fight?
Old Mar 9, 2006 | 08:45 AM
THIS IS...
Sure, any time. That was somewhat of a cromulent statement.
Old Mar 9, 2006 | 08:49 AM
RR5's Avatar
RR5
Forget it. I'll just take my licks and get the seal replaced.
Old Mar 9, 2006 | 08:50 AM
Progress's Avatar
It's business time.
Yes, it embiggens the board.
Old Mar 9, 2006 | 08:58 AM
THIS IS...
Undoubtably so. Glad to see someone else on the internet has an extensive vocabulary, and can form a coherent sentence.
Old Mar 9, 2006 | 09:06 AM
Progress's Avatar
It's business time.
I can actually form more than one coherent sentence. If you donate you will find much more superior sentence structure in OT.
/whoringthisthread
Old Mar 9, 2006 | 09:17 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Wow.. I have never read anything this interesting.. come on people.. he had a question and you guys are taking his questiont o the other level. why insulting each other instead of trying to find or give an idea of what the problem might be. Seafoam won't do any harm in the engine and won't make your tranny leak if you pour it in the engine.. it is just comon sense...... To all
Old Mar 9, 2006 | 09:29 AM
TXT-1's Avatar
You two need to get a room.
Old Mar 9, 2006 | 09:37 AM
THIS IS...
Well, I will have to regretfully pass on that.
Old Mar 9, 2006 | 09:45 AM
RR5's Avatar
RR5
Maybe I did learn something today.
Old Mar 9, 2006 | 10:38 AM
SoonerFan's Avatar
Cletus
that seafoam in the engine does nothing to your tranny?
