VQ40DE has anyone confirmed tranny bolt pattern?
Because he's asking about the bellhousing bolts on the 40... Um???
I couldn't tell ya but I can speculate that it is the same because the Frontier uses the the 40 and some of them have the 6Spd. I wouldn't think Nissan would completely re-engineer the tranny when they have a very stout package available already. Go to the dealer and crawl under a frontier. Why do you ask though? You keep switching motors when your about to get the current one running.
Originally Posted by NmexMAX
Why is this thread labeled VQ40DE?
allen
I couldn't tell ya but I can speculate that it is the same because the Frontier uses the the 40 and some of them has the 6Spd. I wouldn't think Nissan would completely re-engineer the tranny when they have a very stout package available already. Go to the dealer and crawl under a frontier. Why do you ask though? You keep switching motors when your about to get the current one running.
Don't worry bro, I'm keeping the 3.5 for quite a while. I'm just researching the interchangability. If I ever come across a good deal on a 4.0 I'd like to know if it would be feasible to swap it in.
allen
I have an 05 frontier in my garage. I believe the that 6spd from the 350z is the same one used in the frontier, so it ought to work fine.
Just a further thought....
350z 6spd is the same as frontier 6spd so...
frontier uses 5spd automatic also, same unit as titan/armada so...
6spd from 350z would bolt onto VK56DE from titan/armada
That engine is an intake manifold and headers away from 400hp.
Originally Posted by 96sleeper
6spd from 350z would bolt onto VK56DE from titan/armada.
Originally Posted by JClaw
How strong is the 6-speed, really? I imagine the lighter tha car the more reliable it will be, but I'm curious how well it can take really hard drag launches in a 2200 lbs car...
1: 3.794:1
2: 2.324:1
3: 1.624:1
4: 1.271:1
5: 1.000:0
6: 0.794:1
Final drive: 3.538:1
1: 3.794:1
2: 2.324:1
3: 1.624:1
4: 1.271:1
5: 1.000:0
6: 0.794:1
2: 2.324:1
3: 1.624:1
4: 1.271:1
5: 1.000:0
6: 0.794:1
Frontier
1: 4.368:1
2: 2.518:1
3: 1.743:1
4: 1.283:1
5: 1.000:0
6: 0.769:1
Final drive: 3.538:1 or 3.692:1 with the 6spd
Final drive: 3.133:1 or 3.357:1 with the auto
The VQ40 does not rev near as high as other VQ's, with a long stroke (95.5 bore, 92 stroke).
Originally Posted by scrhale
Internals specifics > me
MAYBE we can swap the pistons to stroke the VQ35????
VQ35= 81.4x95.5mm
VQ40= 92x95.5 mm
Well, I haven't blown it up yet. Although I haven't had any serious tire until recently. But from the shear size of the case I'd say its way overengineered. Take a look at my homepage to see what I'm talking about. I've never seen anything as wide.
It's pretty heavy too... 30 pounds heavier than the stock KA tranny. So "overengineered" sounds about right. An overengineered transmission mated to an overengineered engine... sounds good.
It's alright, I have a 2005 350z 6-speed tranny sitting next to my VQ35 in my garage... Just looking for extra peace of mind when I beat on it lol
The stock rods go well before the stock tranny goes.
The tranny is definitely heavier but the motor is significantly lighter. Allen, didn't you weigh the combo. What were the results?
1: 4.368:1? D@mn! No wonder people complain about that first gear. Its basically useless. Its not like the suspension can handle hauling that much weight so it doesn't need a semi-like stoplight gear. Do those things not have 4 low?
Someone on my350z.com said he couldn't get the VQ40 to fit in the engine bay and he said the 350z tranny didn't bolt on. He said the VQ40 was too tall in the engine bay using stock mounts. So he had to notch the block to fit VQ40 crank in the VQ35, and he was saying something about rods not being different also. The bearing size was different I think, and it was a hassle since he bought forged rods and they were not working.
We need a picture of the back of the block or the front of the tranny so we can put this question to rest. The height issue could have been the intake manifold, if not it would be easy to adjust for if you're building custom mounts anyway.
allen
allen
allen
allen
The VQ40 is a taller block to accomodate the stroke, its not the intake manifold that would be the problem because its not very big.
allen
Originally Posted by vsamoylov
ok which stock mounts? and we established that hood clearance is not a issue on maxima.org
Well, since I have no picture or numbers to back up my claim, what I am about to say will still be a little unclear but....
I have seen the two blocks side by side. Not engines in cars, I mean the blocks. They are very different. The 3.5 has the heaxagonal style bolt pattern for the bellhousing, you know like sorta following the outer perimeter of a hexagon shape.
The 4.0 is more closely a circle shape if the bolts were connected with a line.
That description is vague at best, I know.
Hey Allen.. Tim at SCC Mag was looking for you... something about featuring your car in the Hybrid How To section? He said a guy with a VQ in a S14.. so, I assume that's you.. He said he's been trying to get in touch with you..
Travis
Travis
NOOOOOOOOOOOOOOoooooooooooooooooooooo.....there goes the cheap VQs in junkyards. Then again...maybe SR20DETs won't be raped so much.
Travis
Travis
VQ Frenzy in SCC Mag!
.. Reading > me.
