No "How-To's" on changing rear brakes?
Thats cus it is the same as doing the fronts, except you dont push the caliper piston in the same way. On the fronts you use a c-clamp or pliers to push in the piston. On the rears, the piston has to be twisted in. There is a special tool you can get from like autozone, but I just use some needle nose pliers. Just grab the piston and twist it clockwise as you also push in.
Put some blocks under a front tire and the back tire that's still on the ground and release the parking brake. Then just take off the bracket that holds the parking brake cable and that will give you enough slack to unhook the end of the cable from the caliper, then you pull it off like the front. Twist in the calpier piston (with needle nose pliers or the little tool that you can buy from autozone for like 5 bucks), stopping every so often, or reversing a little to keep the boot from twisting up.
Originally Posted by 1NICEMAX
quick question... why is there a need to turn the piston clockwise?
Huttig2009
Sep 25, 2015 03:31 PM
RealityCheck
Aug 5, 2015 06:18 AM
