Dashboard light problem sorry about asking again
Hey guys I posted a few weeks ago wondering what caused my dashlights to flicker and then die. I checked all the fuses and they are perfectly fine, most of my friends and a mechanic suggested a relay switch problem. Is this the most probable explanation? And how easy is it to fix yourself or how much more will I be in debt after all the cash I dropped on prom last night........
Does it still light up, or is it dead altogether?
few things to check:
Rear tail lights, both sides: Check for rust and shorts
Wiper: there are three speed low, medium, and fast: select the medium speed and see if wiper work or moving at the normal speed.
Dome light: when you close the door, does it fade out, or it simply shuts off
if your wiper and dome lights are not working as they should normally, you might want to check your Timer Control Box located under the steering column, behind the security box.
tsi6001
Oct 3, 2022 10:23 PM
vingodine
45
May 21, 2016 12:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
