Lets Talk EGR !
Lets Talk EGR !
Another post about my DEK that is going in. I already ordered a NEW EGR valve and BTP valve, or whatever its called, from Nissan for the install and all the gaskets as well.
My question and largest consern right now is:
Can I totally do away with the EGR system to keep the intake stream alot cleaner ?? I would like NO codes as well, but not sure if thats possible.
I live in a Cold Climate so I wouldnt wanna do anything that would screw up the cold starts. Does anything occur, EGR related, thats crucial when starting the car when its cold ??
Anything you can tell me would be great. Anyone that has done the totally EGR removal. I hate the EGR system and i really dont need it for emissions cause I get it done anyway.
-matt
-matt
i have a 97 maxy with 2001 dek. I have no egr using the 5th gen ivac. Cold start sometimes it won't start, have to give it gas for a bit only when its really cold something you just have to deal with. For the egr i just took off the egr temp out the header and connected it and just put it around my brake lines to keep it out of the way. It use to give a code for egr temp but now its all gone.
I removed the EGR on my setup. Cold start was always a problem for me even when it was 80 degrees out. It usually took 3 to 5 seconds of cranking plus helping it idle for a minute or two. I'm not sure if that could have been corrected with some trickery of the ECU. Then I removed the IACV and the problem got more pronounced. I just live with it. Race cars are supposed to be a bia to start.
Did away with mine as well when I did the VI swap & 5th gen TB. Mine has cold start issues as well but I'm not sure if it's really from the EGR or not. I just welded the EGR temp sensor in the pipe coming out of the exhaust mani so I wouldn't throw any codes for that.
Originally Posted by Broaner
Good idea on welding in the temp sensor. I hadn't thought of that. But because I run a 95 ECU I have no codes anyway.
-matt
Originally Posted by SDot82
I think the egr affects the cold starts because I am using 5th gen IAVC with working egr and I have no cold start problems.
-matt
For my current Mevi setup, I also have sealed up the EGR slot with a good size turn-nut. The EGR still bolts onto the same place fine with everything else plugged in. Never had codes and never had problems.
Before I plugged EGR in the MEVI, the whole inside of the intake Chamber would be filled up with black charcoal film that's kinda hard to clean off. I had to flush seafoam once a month to maintain its clease as good as I can. After I plugged up the EGR hole, the intake chamber is always clean, even dustless, but only with a hint of engine oil; I guess that comes from the PCV. Other than that, Plugging the EGR is the ultimate solution to keep the Intake Chamber clean.
I am also running the setup with a Pathfinder Throttle body. I never had problems with cold start, but our coldest temperature down here is only 28 F. Only thing is that the idle rpms are pretty high upon startup, and it takes about 2 minutes to fully warm up. When I had my stock setup, it only took a little bit more than a minute to get the idle rpm down to 700rpms.
Hope this helps.
Hope this helps.
Originally Posted by matty
Welding in the temp sensor in the manifold will yeild wrong readings anyway. The temp sensor is located at the bottom of the feed tube after the air has come out of the manifold and gone through the system.
-matt
-matt
is the temp sensor u guys talking the one that goes into the EGR guide tube? cuz im doing 00vi install and putting the 5th gen egr guide tube into the 4th gen egr. and the tube has a hole that seems to be for a sensor of some sort.
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
