ALTERNATOR FTL ZOMG My Brake and Battery Lights are on
Last night my car started acting funny right when I started it, after it was sitting for 8 hours. My power inverter for my PS2 started making noise saying that there wasn't enough voltage going to it. And my CD player would shut off if I turned it up loud. I checked the voltage of the battery and got 10.20V when the car was running. I took off my grounding kit and the car was back to the normal 13+Volts.
Half way through today, I started my car and I noticed my brake and battery lights were on while I was driving. The voltage dropped down to about 10.15Volts. I checked the 7.5A ALT S. fuse right near the battery and it is alright. My car's battery will not recharge. Do you think a new battery would solve the problem, or I need a new alternator? My battery is a regular one, nothing fancy about 2 years old. What would you do?
Thanks, Aaron
Thanks, Aaron
OMG The battery and brake light came on at the same time
ALT fuse has blown. It is located under the hood in the fuse box near the battery. It can alos mean the voltage has dropped under 10v. In most cases this means your Alternator is dead/shorted out. Replace the fuse when you replace the alternator.
by Kevlo911
by Kevlo911
since i know the feeling of having a thread not replied to, ill help ya out to the best of my ability.
First things first, check ur belt tension. Believe it or not, if your main serp. belt is does not have enough tension on it, it can slip off around the alternator causing the car to mainly run off the battery, crank from the battery, and drain it as well. the alternator will somewhat turn but will not spin enough to generate the power.
however, u claim that whenu took off the grounding kit for the converter, the power came back to the battery, but did the lights go off?
if the belt tension is fine then i would run the car over to autozone or advance with the grounding kit off, and have them check both the battery and the alternator...also, ur converter could very possibly have shorted out.
The answer to your thread is NEW ALTERNATOR NEEDED!!
Go to your car, start it up and carefully remove your positive connection to your battery!! Only the POSITIVE, if the car turns off, than there is your answer! Your alternator is dead and not charging your battery, so this means your car is running off your battery!! Go and try and let me know what happends!
Change the alternator and you battery will charge back up! The voltage on the battery has been decreasing because the car is runnig on the charge the battery has! But once you have the new alternator on, like i said you will get your charge back automatically
You can get an alternator from O'Reillys for about $130, $75 core charge. The good news is that you can upgrade to the bigger 125 amp one over the 110 one and they have a lifetime warranty. good luck.
Uhh....no i dont think you messed anything up with your grounding kit, To be honest if it was my car i would take that grounding $hit off!! Well on the other hand you can go to the dealer or AdvanceAuto parts or Pepboys to pic one up!! I wouldnt go to the dealer because the price for that will be kinda high!! You can get one at advance auto or pepboys to save you some $$
be sure your not under nissans recall list for the alternator, I was and i am a 97. They can check with your vin
I will let you know tomorrow if I buy one.
Yea the easiest way to know is, look between the radiator and the engine! U should see only one plug from your o2 sensor that comes from your y-pipe if you see 3 than its cali spec....
I am more than shure that your not cali
I changed my alternator today. Picked one up from Auto Zone. Seems like when the engine is at idle speed the whole alternator vibrates. I tightened the two alternator bolts, so I don't know why it's vibrating.
Tomorrow, I will change the Serp. Belt. Can I get one at AutoZone or is the dealer a better place to get it?
Thanks for all the help guys!!!!
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Superbform
Aug 11, 2015 08:10 PM
