Quick! How do you remove the 2k plenum!?
I'm having a hell of a time trying to remove it because I'm trying to get to that last goddam VIAS screw that is on the bottom of the box.
I took out the 8 screws/bolts that are in front of it but it still sticks on there like something is holding it in!
I tried prying it out to no avail!
How do you do it?
How do you do it?
download FSM...or nissan fast system
fast system can be found here (it's what they use in the dealerships for parts/diagrams):
www.phatg20.net
and the FSM can be downloaded there as well in pdf format...there, they have diagrams and cut-away's which allow to see every bolt/nut or screw holding things in and you can match them up to what you have taken out and what may be hiding in a dark corner somewhere...
www.phatg20.net
www.phatg20.net
www.phatg20.net
The FSM only gives me those 8 nuts and bolts. I found 2 more near the TB, i don't know what's left. I can't see anything! OMG, this is annoying.
Originally Posted by MaxBoost925
thanks for the tip bro, but I had the FSM for a long time already.
Originally Posted by steven88
for my manifold, theres two bolts on the back near the firewall...you can't even see it...but when u stick yer hand back there, u can feel it...those two bolts have to be removed, or else the manifold will not budge
Originally Posted by 9DTALON
Don't forget the EGR tube thats bolted to it also. It would suck to mangle it up and have to replace it.
bump for answer!
ok first off, i finished my VIAS fix.
secondly - don't try taking off your plenum if you have large hands, because you won't be able to get the 4 screws that hold the rear of the IM on.
third - HOLY CRAP! removing the power valve makes a huge difference in power! the car now pins me back from 1st and 2nd gears at WOT. 20 more whp, no joke, according to butt dyno (more power feeling than when I did y-pipe and full exhaust). I really don't notice any low end loss at this point because I havn't done any "normal" driving yet.
...I havn't done me timing advance yet, so we'll see what results that will bring
14.8 at the track?
14.8 at the track?
14.8 at the track?
14.8 at the track?
you should be in the 14.8 easily...lets just see how those trap speeds are...or how about dynos? then we will talk
ES motor mounts finally pressed in by that time, along with a 17 degree advance.
I want to make 14.5. with the help of cold air at nighttime.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
