WTF? Enkei RS6 + SMALL pothole at 25MPH
i guess it just hit at the right spot, and the metal just cracked, and kept going...... it also may have been a manufacturer defect..... id call the company... although it does look like you were going more than 25 MPH....or that was some seriously weak aluminum
Originally Posted by MyGreenMax94
Whoa!
Pic of pothole?
Pic of pothole?
I tried to dodge the first one by turning to the right, and I clipped the second one with the front passenger wheel.
Originally Posted by Maxi113
How fast were u going? It looks like a wolverine chewed on it
wolverines....my uncle and i hunted wolverines.....
and u can't drift in these cars, lol unless ur on a dirt road or something.....stupid FWD cars......
Originally Posted by kcidmil
Had he been going faster... make a hard, quick turn and pull the e-brake, you'll slide, dirt or not. Then when you're ready, turn into the skid, stomp the gas, and release the ebrake.
Originally Posted by Matt93SE
Jayson, Let me send that to a friend of mine before you ship it to Enkei. he works in metal failure analysis and can posibly provide more insight on it for you.
Okay,
I may try to bring it to you today.
And BTW, do you happen to have a spare window switch? Mine is on the blink.
The master switch can only lower the other 3 windows, not raise them
. I can raise them at the other switches, but my passenger rear is already broken, so it's stuck down...and as you know, it rains every damn day here
I might have a single rear switch or something, but not sure. we can tear it apart and see if I can't get it resurrected though.
And guys, FWD cars do not drift. they drag a$$. that's not drifting. drifting involves POWER OVERSTEER, not A$$ DRAGGING!
Has that damn movie started infecting minds here ALREADY?
I would contact Enkei about maybe getting a replacment wheel...
that really sucks that your rim broke like that. i have honestly never seen that before.
i have known a lot of people that have had similar things happen to them at rather low speeds. they all had Enkei's and they all now refuse to buy them ever again. i wonder if they are not making them as good as they use to? Now out of everyone that i know that it happen to they all had low pro tires on. Wonder if that makes a difference?
just because it's a Maxima forum doesn't mean there's no ricers trying to drift.
If you wanna drift your FWD, then go to hondatech.com and stay away from the rest of us.
I hope I never see a Maxima "drift" on purpose, at least until they are made into RWD cars...
Originally Posted by vansskaterfreek
i had an auto tranny, and the starter didnt reach the VG flywheel
and i didnt have a FULL wiring harness for the VE motor
The engine harness is pretty seperate from the rest of the car's functions
That is really not that big...I would contact Enkei about maybe getting a replacment wheel...
I called them today. They told me to take it to discount tire and have them inspect it and return it to the factory.
Wow, thats pretty bad, I would contact Enkei and explain to them the situation, chances are they will replace the rim. That looks to be a manufacturing issue. There is no reason that rim should have separated like that. They should give you a new rim. And if they are a good company, which they are they should help you out, although you will probably have to ship the old rim back to them so they can look at it and try to figure out what happened. Good luck and sorry for your mishap. Bruce
Didn't notice. Why would someone shred it like that?
