Anti-Squeal Application
I used the spray can version of anti-squeal the last time I did my brakes. I sprayed some on the back of the pad and the back of the shim, then put the shim on the pad. I then appied the anti-squeal to the back of the shim (the part that comes in contact with the caliper). Well, I have squeal again.
I assume the application was too thin (though I sprayed it twice). Last night, I picked up version of anti-squeal that you spread like peanut butter.
Where should I apply? (between pad and shim or just to the back of the shim where it will contact the caliper)
Also, do I need to remove all the old anti-squeal that I sprayed on?
From what i hear, you are supposed to apply the anti-squeal to the outside of the shims. When doing my brakes, I did it the 'wrong' way and put it between the shims and pads.
Interesting how a brake hardware kit or pads from the dealership don't include anti-squeel grease, but they'll include other grease for the sliding pins.
Really, forget the anti-squeal stuff and instead get silicone based anti-seize grease. This's what you want:
Jae
Jae
For the rear brakes, I eliminated the brake pad shims altogether and used anti-squeal compound on the back of the pads=no squeal! If you use the shims, apply anti-squeal on the shims, not in between the shims and pads.
Well, I tried the high temp grease the first time I did my front brakes. That only stopped the squeal for about 5k miles (maybe less). The second time I took the brakes off, I applied the anti-squeal aerosol to the back of the brakes and the inside of the shim. It stopped the squeal for about 5k miles.
After this thread, I took the pads off again. Anti-squeal was still on the pads and inside shim. I applied two coats to the back of the shim, thinking the noise was being transmitted through the caliper. 500 miles later it is squealing again...worse this time.
I have Axxis pads which seem to be the issue. When looking at the brakes this last time, the anti-squeal seems to have sealed the shim to the pad pretty good. Would soaking them in brake cleaner dissolve this allowing me to remove the shim? How much are new shims from the dealer?
You're not gonna need the old shims if u get new ones, so get the old one off any way u can. A knife, blade, or flat screwdriver helps. I don't think brake parts cleaner dissolves the rubbery anti-squeal, but worth a try.
Jae
Jae
Enthusiasts will say change either the rotor, or the pad, but not both at once. Average driver won't notice the difference.
Turn/replace the rotor as necessary. When the pads are out, inspect and measure the rotor and go from there.
Jae
Jae
Jae
Jae
A scraper, like putty knife, works for taking off the old gunk. I stopped using that AntiSqueel stuff and instead use hi pressure, hi temp red grease.
I contacted Dave Zeckhausen this morning:
http://www.zeckhausen.com/bedding_in_brakes.htm
He suggested re-bedding. I'll report back after a few weeks and see how this works.
After re-bedding, I do see pad transfer on the rotors as well as a bluish tint.
After the re-bedding, the brakes have been silent. 2 weeks now.
I followed the directions and did 60 to 10mph stops about 8 or 10 times. The brakes were quite hot after this but I did note the dark gray transfer of pad material and a slight blue color (meaning the correct heat range had been achieved for bedding).
Found BG Stop Squeal
one of the few places to get on the online...search for an hour and ran across this in another forum. www.StopSqueal.com
Apr 16, 2020 05:15 AM
carid
Sep 9, 2015 05:06 AM
umnitza
Sep 1, 2015 01:03 PM
Daniel B. Martin
21
Dec 2, 2002 05:55 PM
