Code 09-08 ECTS.What the....?
Old Aug 16, 2006 | 07:17 AM
ArcticW's Avatar
Pulled a bunch of codes , and here's what the yellow blinky light said:
03-04 ( We ALL know what that is...)
01-03-
09-08- Both bottom codes came out to be "Engine Coolant Temprature Sensor"?...
So, how critical is this Engine Coolant sensor anyways? I know the KS needs to be fixed, but do I need to take care of the ECTS, or can it wait until next payday?
Old Aug 16, 2006 | 07:30 AM
MDeezy's Avatar
ECTS isnt critical, you could wait till next payday. Sensor should cost about ~$20 to replace and 2 mintues to do it.
Old Aug 16, 2006 | 10:18 AM
ArcticW's Avatar
cool, cause I just got off another thread where another .org member got an ECTS code and it caused his car to stall....and I've got the same exact sypmtoms, so funny thing is, why does the ECTS cause the car to stall?
Old Aug 16, 2006 | 10:37 AM
MDeezy's Avatar
Its happened to some, I dont see why it would cause the car to not start but who knows I could be wrong, or it could have not been the ECTS that was originally causing it. . . who knows.
I threw the code for a couple of weeks with a bad thermo that was stuck open. Car started just fine. If anything be prepaired should the car not start so atleast your not surprised if for some reason that happens, but I cant see it happening.
Old Aug 16, 2006 | 05:55 PM
colinnwn's Avatar
A bad thermostat will only cause your engine to run cool, get worse gas mileage, and be slightly more susceptible to carbon deposits. If the ECTS is fried open, when starting, the computer won't know to provide cold engine fuel enrichment. That should cause the car to hard start and run crappy till it warms up.
Old Aug 16, 2006 | 07:02 PM
MDeezy's Avatar
but would still let his car start. This would be what he'd have to deal with till he accumilated the funds to replace it. It depends on how bad his current sensor is. I assume his start up isnt anything ab-normal other wise he would have added that to his post. . . unless he left it out.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
