3.5 Done some new codes
Well i finished the 3.5 swap about 2 weeks ago now I pluged in the odb2 reader and im getting following codes
P0440 - I had this before the swap evap controll system.
P0105 - Absolute pressure sensor "I think that i just need to look at vac" im not worried about that
P1220 - But this kinda worries me " Fuel Pump Control Module" now what is that all about anyone have any ideas thx
I would really look into the fuel pump issue like a hawk. If your fuel system is faulty, you may sabotage the whole swap. I didn't have this issue, so I really can't tell what's going on.
For your evap codes, you may want to recheck your vacuum lines again; and make sure you got them all in the correct positions.
My swap is done, I have the details in the all motor forums, come check it out.
Good luck with your swap, hope everything bids well.
-Peter-
-Peter-
-Peter-
Fuel pump usually gives acoustic symptoms before it goes out. You'll hear some wierd noise from the rear seats area and it's the fuel pump most of the time. But if you ignore it, it would go out all of a sudden.
For your EVAP codes, why don't you replace the solenoid? Try to find the bad vac when you can. Update what you find...
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
