Inline Pump Removal? Links in FAQ don't work!
Old Sep 9, 2006 | 03:15 PM
MaximaEvolution's Avatar
I want to install my walbroHP and I need to remove/bypass the inline pump. Any help? Thanks in advance!
-Mike
Old Sep 9, 2006 | 05:22 PM
BlackCat's Avatar
RIP '98 Maxima SE
Here's the instructions I used:
http://vbxmaxima.8m.com/fuel%20pump.html
It also has pics!
Old Sep 9, 2006 | 08:02 PM
matty's Avatar
Just take the inline pump out, along with the wires out and replace the lines where they should be. Its only inline with the fuel line coming from the Fuel Rail to the return, NOT from the Tank to Fuel rail.
Old Sep 10, 2006 | 07:42 AM
what is it wired to? Is the return line obvious to see under the car? What does the inline pump look like? Thanks guys
Old Sep 10, 2006 | 07:50 AM
matty's Avatar
Return line will run right past the fuel filter on the left of it. You can access it from the top. Its kinda obvious beacuse its running towards the rear of the car.
It should just be wired to a activation switch with has power and a ground.
-matt
jerrod99_se-l
Aug 27, 2015 08:27 PM
mikekay
Aug 10, 2015 12:52 PM
kirkhilles
Aug 8, 2015 10:53 AM
13Maximasv
Aug 7, 2015 10:56 AM
kenc15
Aug 5, 2015 08:29 AM
