05 G35 sedan sport 6mt and 02 maxima 6mt HP number and etc...
Ok, Graph is comparing a 05 G35 sedan sport 6mt dyno and a 02 maxima 6mt dyno numbers
1.) the maxima pulled better numbers in third , while the g35 got better numbers in 4th?
2.)sorry for the black and white, something is wrong with my scanner, But you can see how close the numbers and then the g35 keeps gaining after 5.5 k while the max just starts to drop HP..
3.) G35 has a intake, Max has intake and safc
4.) at least i put down more TQ...lol
5) what gives the g35 that top end , is it the ecu or the intake manifold? How can I get that top end on my VQ??
Think the G35's topend relies heavily on VTC. For the longest time everyone thought it was the IM but when people installed it without spacer they actually lost area under the curve (although tq curve was a lot smoother). Most of the difference there would then be due to VTC.
If you want to read a little more check out this thread. It should also be noted that this was performed using the 287hp manifold and not the "revup" 298/300hp version.
Also, no doubt the G/Z's exhaust helps a bit as well.
Originally Posted by sloppymax
i was under the impression the 06 G35 with a 6spd had a redline of 7k?
i believe its a combo of intake manifold, exhaust VTC's and timing. my belief is that when people put the manifold on, they didnt see the gains because of a lack of exhaust VTC's, i still think it is superior to the max manifold, just not on a max.
this was done on the 298hp rated g35, i forgot if my friends car is the 05 or 06, he said its got 298 tho so which ever year that is
Im not sure why i didnt keep climing to 7k, i think they guy on the dyno just let off but the line stoped climing after about 6.5
realy , mine seemed to put down better numbers in 3rd.....??
Originally Posted by Hoooper
just because they are better numbers doesnt mean they are right. if you dyno in first you should get pretty good numbers too (i would think, dont flame me if thats not true). the max 5 and 6 speed should dyno in 4th. its not about better numbers, but the ratios
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 7, 2015 05:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
