45 to a 50 series tire...'99 SE-L
Old Oct 16, 2006 | 01:51 PM
MrEous's Avatar
^ Jeff™
Just a really quick question...
I'm going from 225/45-17 (Toyo Proxes4) to 225/50-17 (Nexen) tires for my '99.
Getting the Nexens for dirt cheap, $231 for the set.
I wanted to ensure I wouldn't have any problems. I searched extensively and couldn't find any negativity towards rubbing but there may be some speedo error, which I can deal with.
I am really only concerned with rubbing though since I have an Eibach drop, which is fairly mild.
Any help/advice is helpful.
I just put a box with 3-JL 10s in the trunk and do have mild sagging...but with the extra weight added I am no longer worried about keeping my performance up.
Old Oct 16, 2006 | 02:29 PM
DaEnigma's Avatar
I do not think rubbing will be an issue as the width and hight is not all that radical with Eibach springs...
Keep in mind the ideal size is 235/45-17 which is only 0.1% slow on the speedometer reading.
Stock tire size is 215/55-16
sidewall:4.7in
radius:12.7in
diameter:25.3in
circumference:79.5in
Revolutions per mile:797.0
New tire size 225/50-17
sidewall:4.4in
radius:12.9in
diameter:25.9in
circumference:81.2in
Revolutions per mile:780.0
The new tire will provide a speedometer reading ~2.2% slower than the actual speed so when your speedometer reads 60mph it will really be ~61.3mph.
http://www.miata.net/garage/tirecalc.html
Old Oct 16, 2006 | 06:04 PM
MrEous's Avatar
^ Jeff™
You're right...thank you.
James92SE
142
Jan 2, 2024 09:23 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
umnitza
Sep 1, 2015 01:03 PM
Team STILLEN
Aug 10, 2015 04:29 PM
