Blown shock?
Blown shock?
Well, the front driver side is sitting lower than the passenger side, you could also tell by the wheel gap too. I'm on stock suspension too. Could a blown shock cause my car from drifting to the left? I got someone to check my alignment before and they said it was fine. So no clue...
Originally Posted by frankd121
Go over a speed bump. If the driver side keeps bouncing after the bump (>4-5 times) then you've got a blown shock.
How big of a fella are you? Not trying to be rude but I've seen people who are pretty big cause this in several cars...namely Sentra's but its still a possibility. The Shock plays very little in the ride height of the vehicle. 95% of the height is the springs, you may also have a look at the suspension members to see if anything is bent.
I'm not big, which is why it seems weird for the driver side to be sitting low. I did try pushing down on the front of the car and the passenger side bounce back and the driver side doesn't.
yeah well thers def something wrong then.. im not sure of what im not good with suspension stuff... ur gunna have to ask the experts? Dr. klop and others?...have u looked at both and compared them to see if there is anything visually wrong?
Blown shock can make the car pull to the side, however, it will not make any difference in how low your car sits when the car is parked. (shocks resist only suspension movements)
What exactly did you mean when you said that the diver side did not bounce back? You pushed on it, it compressed and did not come back to its original position??
Do you hear any noises coming from your suspension?
Also, if it’s not a problem, could you post your alignment sheet? It might help us identify what could be wrong.
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Stagnet04
Sep 14, 2015 11:28 PM
