Sale: VG, VE, and VGET Parts
Old Oct 30, 2006 | 12:14 PM
Chris Gregg's Avatar
Get Off My Lawn
Here is a list of parts I've still got around. LIST UPDATED: 6/24/08.
Hope someone needs something! Make me an offer! Email me directly for questions: Mxmumpwr@aol.com
Misc. Parts: (VE/VG) A/C/heater blower motor; Analog climate control; Deck lid(drk/gry); Hood(drk/gry); Trunk/gas lid release switch; Front/Rear bumpers and covers; crank and transmission side axle splash guards; Passenger inner fender; stock corner markers (R side only); Doors and window glass; Brake booster; ABS sensors and ecu; Air bag system (complete); Cruise control system; power steering pump and resourvior; Coolant resouvior; '89 side mirrors (non-heated); Rear bose amps w/brackets (no speakers); radiator; windsheild cowl; Dash Trim: peice around guages, trim for switches (behind steering wheel), Passenger's "A" pillar, bottom dash cover (below steering wheel); stereo console and trim cover; kick panels; center consoles (where shifter and e-brake are located); Several center console lids; glove box and trim panel; as well as cloth front and rear seats.
*Random Tech Cat. Converter: 2.5" (922211) New in Box.
** Brand new set of R-33 Skyline tail lights. These are straight from Nissan and in perfect/mint condition.
*** Autometer A/F guage and sensor. Comes with all wires/components to install. You can see images on my Cardomain page.
*** Autometer Mechanical Oil Pressure Guage. Works perfectly. Comes with everything to install. I'm running thicker oil = higher oil pressure and so I need an electronic guage.
****New Headlight Bulbs: 9007 (x3) and 9004 (x1) Blue bulbs. These are higher than stock wattage. $5 plus shipping per set.
VG: VG block and heads (no rockers or rods); lifters (all good/pump up); flywheel; auto flex plate; Stock Ign. Coil; stock air box and intake piping; ecu (#a18-a13-e71 <9114>); stock injectors ('89-91); other various relays and electronic components.
VE: knock sensor, various electrical components (ie: cam position sensor and power transistor for the coils).
VGET: fuel rail (top feed) and injectors (not tested); top engine designation plate ("3000 Turbo").
Make offers! Many other peices as well, email for specific questions.
Old Oct 31, 2006 | 05:41 AM
Travis92se's Avatar
What color trim do you have for the "A" pillars?
Old Oct 31, 2006 | 11:09 AM
HoMiE_TeLeFrAg's Avatar
Message sent for the VG ExhaustManifolds...^_^-Ben
Old Oct 31, 2006 | 11:24 AM
Duckman540i's Avatar
VE Powah!!!
You happen to have good rear Bose 6x9's?
Old Oct 31, 2006 | 02:54 PM
Rndm187's Avatar
Do you have an oil pan for a vg
Rndm187's Avatar
Do you have an oil pan for a vg?
Old Oct 31, 2006 | 06:16 PM
Get Off My Lawn
1. Travis: A-pillars are black.
2. Homie: No message recieved (private or personal) for VG exhuast manifolds. I've got both, actually two sets. Whole, running engine has manifolds and stock "Y" pipe.
3. Duckman: No good 6x9's, only amps and brackets.
4. Rndm: No oil pan for VG available (only on running engine). Will not remove, sorry. Do have oil pan for VG30ET. I know that's of no use though.
I do also have a pair of front seats: blue/black checkered kind (stock).
Old Nov 1, 2006 | 09:17 AM
How much for the stock rear manifolds, Y pipe, and cat with shipping to 46516? -Ben
Old Nov 1, 2006 | 09:31 PM
Get Off My Lawn
Homie: YGM
Old Nov 1, 2006 | 09:52 PM
Get Off My Lawn
Homie (Ben): Appearantly you cannot recieve private messages yet and you've failed to provide your personal address for contact. Here is a cut/paste of the email I wrote:
Clarify "stock rear manifolds?" Are you stating you want the stock VG (Max) manifolds; left/right?
The Y-pipe is cut pre-flex pipe.
Cat converter is seperate and brand new in box. One converter box opened for inspection only, the other cat is still sealed from Random Tech. Never been installed. You will also need to clarify which cat you would like. One is longer than the other, but both are set up for direct bolt up. You can have tips of pipes cut off and the cat welded up directly to existing exhuast. Otherwise, you can get an install kit.
Shipping from me to you: 46516 was estimated on UPS.com. I will have to measure the box dimensions as to the y-pipe. I am estimating it to need to be about 30x20x20 and between 20-25lbs (due to box size, billable weight up to 70lbs so weight matters little). Therefore, based on the box size and the zip code you provided, shipping should be $30. Please feel free to verify estimate based on this information at UPS.com using my shipping zip of 37604. Make me a reasonable offer.
Chris
Old Nov 2, 2006 | 02:55 PM
Gregg, I checked over the VG motor last night...and I will require both left and right exhaust manifolds the car. As far as the cat goes, I guess the opened box one will do fine. The Y-pipe sounds like it fits the bill provided its all still in good+ shape. How does 175+shipping sound? Let me know...-Ben
E-mail: HoMiE_TeLeFrAgGeD6377@yahoo.com
Phone #: (574) 294-2333
Old Nov 2, 2006 | 08:16 PM
Get Off My Lawn
Ben, Agreed. YGM.
Old Nov 10, 2006 | 04:29 PM
Get Off My Lawn
Two new items added. R-33 tails and BMW Headlights. Images are on my cardomain page.
Old Nov 12, 2006 | 02:38 AM
DaWifey's90's Avatar
what can my max do for me
how much for the Jacobs' coil and what part number is it?
Old Nov 12, 2006 | 06:48 AM
capblye's Avatar
im looking for stock Bose speakers .... email sent
Old Nov 12, 2006 | 09:22 AM
Get Off My Lawn
Capblye: YGM. However, email stated "im interested in the rear bose amps you have." I have amps and brackets, speakers are busted. Please clarify.
DaWife: Make me an offer on the coil. I've used it on my Max and a '66 Ford truck with no problem. Only swapped it out becuase the original ICE pack I had (ecu) failed and they sent me a whole new system, so I swapped out everything. They are identical coils though. I still run the one on my Max. The only number on the coil is #826-72-020. I tried running the number on the Jacob's site, but nothing came up. Regardless, the number on the site is 380846bt; leave off the bt and the standard Torquer Coil will come up. There is also an image on my cardomain page. If you decide to purchase, we'll talk about install. Not complicated, but I have a few suggestions.
Check out www.Jacobselectronics.com which states "A special variation of our Torquer Coil is used which provides longer duration, higher current sparks. This substantially improves mid range performance and throttle response." This is the comment about the coil in regards to the ICE Pack system.
Old Nov 12, 2006 | 11:33 PM
VE Powah!!!
I can't seem to view your cardomain. Could you post pics of the E36 lights?
Thanks.
Old Nov 13, 2006 | 07:39 PM
Get Off My Lawn
Here are a couple of the images. Not sure why you can't view the page. I'll check the link I've provided. You have to click the link in my main post, at the bottom. Here it is again.
http://www.cardomain.com/ride/329804
http://memimage.cardomain.net/member.../329804_51.jpg
http://memimage.cardomain.net/member.../329804_50.jpg
Old Nov 14, 2006 | 09:18 AM
Rndm187's Avatar
I need the two bulb sockets for the front corner lights .......and the trunk board if possible
Old Nov 14, 2006 | 05:28 PM
Get Off My Lawn
I can scrounge up the sockets, will be this weekend as I will have to pull from the junkyard car I have next door. Trunk board will require a big box and would otherwise likely split if tried to fold. Or, are you talking about the peice over the spare tire? I've got that but it droops a little in the center. Email me directly at Mxmumpwr@aol.com and I will get back with you this weekend after I make sure I got the parts and all in sell-able (ie trunk board) shape.
Old Nov 14, 2006 | 06:35 PM
Maximahappy22's Avatar
how much for the VG IACV to 98006.
Alex
Old Nov 16, 2006 | 07:18 PM
Get Off My Lawn
Maxhappy: UPS says it will take 5 days, cost at $11.00. Make an offer.
Old Nov 20, 2006 | 03:54 PM
heresmymind
VG fuel rail with injectors?
Old Nov 20, 2006 | 07:39 PM
Get Off My Lawn
heresmymind: Got them on a good, running, complete engine. No stutter/miss/or hesitance when I ran engine befor pulling. Car pulled engine from was totalled cosmetically. Make me a good price and I will start parting this engine out.
Rndm: Checked with junkyard my car was at. They finally got round to scraping it. No bulb sockets, sorry.
Rndm: If still interested, it looks like several people interested in parting out my complete and running engine. Therefore, if still needing oil pan, I will remove. Make me an offer.
Old Nov 24, 2006 | 10:29 AM
MaximaLeSS's Avatar
How about a good running vg head? How much & what kind of miles are on it?
Old Nov 24, 2006 | 11:25 AM
Greeny's Avatar
¯\(°_o)/¯
Hey Chris..Got any window regulators?
Old Nov 25, 2006 | 10:01 AM
Get Off My Lawn
Maximaless: I have both L/R VG heads that I just pulled off my original engine from the car. Has about 180k miles on them. No problems, except expected oil buildup. It would be good if you could have springs tested and the assembly thoroughly cleaned and inspected. Both still assembled with cams, although I did remove the rocker assembly bolts. I still have all peices, but someone asked me for the bolts and washers, so I removed. I'd personally have no hesitency putting them into another stock VG. Make me a reasonable offer. I'd need your zip code to calculate shipping.
Wayne: Sorry buddy, no regulators. Actually, had my rear driver's side go out a few months ago. Of course had other priorities going on with the car so not fixed yet.
Old Dec 14, 2006 | 07:04 PM
Get Off My Lawn
Still need to move some parts! What's sold has been edited from the original post. I'd be interested in doing some trading. I'm looking for a 4v pre-out head unit. I'm also looking for an oil catch can. I'd also be interested in some leather seats (I know there are so many people out there looking to get rid of them! *sarcasm). I also need a driver's rear window regulator. Email me directly at Mxmumpwr@aol.com for questions/interests.
Old Dec 15, 2006 | 02:36 PM
Sgibb's Avatar
do u have stock fogs u wanan sell?
Old Dec 17, 2006 | 09:55 AM
nubiannupe's Avatar
OG Maxima.org Member
Chris, I might have a 4v pre-out HU that I'll trade ya for the headlights. I'm on my way to work, so let me check and I'll get back to ya with make/model/ etc..
Old Dec 18, 2006 | 05:37 PM
Get Off My Lawn
Sgibb: I do not have stock fogs. Only the plastic casings w/o lenses.
Nubi:Interested in HU. Email me directly to discuss details and what you're looking for out of the trade.
Old Dec 18, 2006 | 08:54 PM
nubiannupe's Avatar
Email sent, man...
Old Jan 5, 2007 | 09:57 PM
mtcookson's Avatar
If you still have your driver's side a-pillar cover I'll take that off of you. Just name a price shipped to 67349 and I'll send you the money asap.
Old Jan 7, 2007 | 10:02 AM
Get Off My Lawn
Mtcookson: YGM.
Old Jan 25, 2007 | 06:35 PM
Get Off My Lawn
Still got bunches of parts! Lots of miscellanious relays and tons of factory screws, nuts, and etc.
Old Feb 12, 2007 | 01:27 PM
dvollm's Avatar
hey how much do you want for the r33 tail lights as well as do you still have the bmw headlights
Old Feb 12, 2007 | 07:45 PM
Get Off My Lawn
BMW lights gone via trade with fellow .orger recently. Should have been removed from list, I'll double check.
Yes, still have r33 tails. I'll not take no less than $400 plus shipping for them. These are not the used or aftermarket crap off ebay. These are brand new, straight from Nissan, stock tails and covers (4 peices). I paid over $500 plus shipping originally and will accept a loss, but no less than the above price. Sorry if too high, but if I can't get at least that, I still plan on installing them at some point so I'd rather just keep them.
Old Feb 15, 2007 | 12:42 AM
Camfantasy's Avatar
got a power steering pump in good shape?
Old Feb 15, 2007 | 02:56 PM
kycyk's Avatar
Just have to throw in a good word for Chris.. he took a look at my 3rdgen a few weeks back .. and I'm still trying to decide whether I want that VG30
I've seen all the stuff he's trying to sell, it's good stuff.. buy it now people!
Old Feb 15, 2007 | 04:00 PM
Greeny's Avatar
¯\(°_o)/¯
Bah!.....Chris can't fix a bologna sandwich..
