What To Do At 60k Miles?
My 2001 Maxima SE is about to hit 60,000 miles. A milestone for my car.
I'm going to have it serviced in probably a week, and just wanted to know if there any special sevices that I should done to the vehicle. I need to have the brake rotors and pads changed anyways, so that will be taken care of. Do the fluids need to be changed at 60k miles? Tranny fluids? Let me know.
I also need to change the filter on my Injen intake as well. What size filter can I place on there? I was thinking of just ordering a new Injen filter for it since it has worked for me without any MAF issues. Where can I get one of those?
Thanks in advance!
~ Kirk
Thanks in advance!
~ Kirk
Originally Posted by llama
Keep driving your car until you hear some clunking or something, or you feel a loss of power, then get it serviced.
Originally Posted by SEmy2K2go
What kind of advice is that?
If this was supposed to be funny, it did not come across that way
Thanks in advance!
Won't hurt to change your PS fluid too. I used Mobil 1 ATF.
a) Transmission fluid (Personally, I would remain old school and change it every 15,000 miles)
b) Coolant (IMO, that should be changed every 6 months)
c) Spark Plugs (maybe)
d) Check CV joints to make sure that the boots are in tact and not leaking grease
e) Change (or clean if you have a washable one) air filter.
That's all I can think of.
60k service is not that big... Its just alot of checking to see if anything is wrong. Highly recommend AT Fluid and Coolant... Brakes and Rotors definitely... Also check your shocks, make sure they are no leaking.
I can't think of anything else... I did the bulk of that when I bought the car just to do em.
I just bought an '03 SE/TE 6spd with 53K on it and plan to do the following:
(Before Winter)
- register it
- change tranny fluid and coolant
- get winter tires
(when spring is coming)
- buy new summer tires
- change brakes/rotors/brake lines/brake fluid
- install K&N intake
- replace fuel filter
- check/replace sparks (may or may no do this depending on what they look like, should be good at 60k on stock NGKs)
After that i'll get to the simple mods i want to do like RSB, FSTB, STS 2-piece mod and that's gunna be about it for my whip. For the fluid changes i usually just take it to like my mechanic and he'll check the other more obvious stuff like CV Joints, Belts, etc.. but you should be good at 60k.
have fun!
(Before Winter)
- register it
- get winter tires
have fun!
(Before Winter)
- register it
- get winter tires
have fun!
(Before Winter)
- register it
- get winter tires
have fun!
Injector Flush
TB Cleaning
Decarb
PS Flush
Tranny Flush
Brake Fluid Flush
Coolant Flush
<<pretty much all fluids by now should be flushed, if not already>>
Check Belts/Pulleys
Regular Stuff (oil change, air filter, etc)
TB Cleaning
Decarb
PS Flush
Tranny Flush
Brake Fluid Flush
Coolant Flush
Check Belts/Pulleys
Originally Posted by 00MaxSE
Nice find. That's what I want. Does it have navi? Got pics?
No Nav, everything but. HLSD, Meridian, Titanium Package, Frost Leather....etc..
No pics yet, it's bone stock. Super clean exterior except for some light scratches on the hood and a scuff mark on the rear bumper. Pristine interior except it needs some new Max matts.
I gotta get some pics soon, but it's not hard to find a bone stock Polished Titanium 5.5Gen SE on here... I'll take some pics of mine soon.
Paid 15.5k for it and it has 53k on it. A little more than i wanted to pay but what's an extra $500-$1000? $10/month more..... GIMME!
tranny flush
coolant flush
brake fluid flush
power steering flush
oil
oil filter
oil pressure sending unit ( check to see if it is leaking )
brake pads ( check them and see if they are low )
rotors ( check them to see if they have grooves in them )
brake lines ( check them and see if they are cracked )
intake filter
replace fuel filter
spark plugs
clean coil packs
in cab filter
rotate tires
check cv joints
check shocks
injector flush
clean tb
ac belt
power sterring belt
pcv
tighten throttle cable
exhaust hangers ( check all of them and see if any of them are broken )
sway bar end links
sway bar bushings
upper and lower ball joints
tie rod ends
rack and pinion dust boots
bump stops
shock dust boots
coolant flush
brake fluid flush
oil
oil filter
intake filter
replace fuel filter
spark plugs
clean coil packs
in cab filter
rotate tires
check cv joints
check shocks
injector flush
clean tb
ac belt
power sterring belt
pcv
sway bar end links
sway bar bushings
tie rod ends
bump stops
shock dust boots
Originally Posted by Zero Deuce SE
Unless you are driving under extreme conditons you are replacing good fluids if you change tranny fluid and coolant at those intervals.
Originally Posted by ZIPPIN
Regardless of miles, I think it would be a good idea to change fluids in a 6 year old car
I wasn't talking about a 6 year old car. I was talking about the 6 month coolant change and 15,000 miles tranny fluid change.
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
hntwhttail
Sep 12, 2015 03:43 PM
