FS:Engine Parts
Old Nov 7, 2006 | 08:35 PM
Maxima_Joe's Avatar
4th Gen Parts King
FS:Engine Parts
I'm starting to tear down another VQ30 engine and will be recycling the aluminum.
So i have every part other then coilpacks. Anybody need anything?
Old Nov 7, 2006 | 08:51 PM
shadyonedeath's Avatar
Omg...where did you get all those max's? Junk yards?
How much did you pay for all that!!! Lmao
Old Nov 7, 2006 | 09:02 PM
goldtooth's Avatar
I need the Boost aka ram air sensor that sits on the top of the snorkel by the front of the engine, I have a 99. How much would it be shipped?
Old Nov 7, 2006 | 09:05 PM
Maxima_Joe's Avatar
4th Gen Parts King
None of them came from junk yards. I got a few locally,a few from ebay,a few from members here,etc.I'm purchaing another one this week as well.They were all purchased in the last year and i spent around 15-20 grand
Maxima_Joe's Avatar
4th Gen Parts King
$15 shipped
Old Nov 7, 2006 | 09:12 PM
Studio718's Avatar
I need this bolt that bolts to the tranny/shift linkeage.
it allows the shifter to be placed in neutral...without it it's hard to put the csr in gear unless you cut it off.
and a 96 passenger side fog light
pm me.
Old Nov 7, 2006 | 09:25 PM
Maxima_Joe's Avatar
4th Gen Parts King
pm me.
Sorry no manual trans parts or foglights.
Old Nov 7, 2006 | 09:47 PM
nguyen925's Avatar
any full set air bags? passenger + drivers ? tan/beige and to fit a 99 GXE
Old Nov 7, 2006 | 09:49 PM
Maxima_Joe's Avatar
4th Gen Parts King
Sorry no bags that will fit a 99.
Old Nov 12, 2006 | 09:12 PM
Maxima_Joe's Avatar
4th Gen Parts King
Anybody else?
Old Nov 13, 2006 | 05:36 AM
basspunk316's Avatar
what year is the maxima you're parting out right now? i dont suppose you have an 00-01?
Old Nov 13, 2006 | 05:38 AM
coaster's Avatar
How much for 6 coil packs ('95) shipped?
Old Nov 13, 2006 | 08:01 AM
natty99's Avatar
uhh, he said he doesn't have the coil packs already!
Joe - how much for the upper and lower intake manifolds? Also, I want to know what year max these parts are coming from
Old Nov 13, 2006 | 05:02 PM
padam07's Avatar
You wouldn't happen to have starter?? How much shipped to 01542??
thanks,
adam
Old Nov 13, 2006 | 08:40 PM
Maxima_Joe's Avatar
4th Gen Parts King
95-98...........
Old Nov 13, 2006 | 08:41 PM
Maxima_Joe's Avatar
4th Gen Parts King
$60 shipped for both They would be off a 96 engine
Old Nov 13, 2006 | 08:42 PM
Maxima_Joe's Avatar
4th Gen Parts King
thanks,
adam
I don't thinks so but will double check. If i do $50 shipped
Yes i do have one.
Old Nov 13, 2006 | 10:01 PM
DjMoney's Avatar
You wouldn't by any chance have any working knock sensors. or o2 sensors. i also need tan vents if you have any.
Old Nov 13, 2006 | 10:42 PM
Maxima_Joe's Avatar
4th Gen Parts King
I do have a few working knock sensors.They come with harnesses as well $40 shipped each.Possibly o2's.Which ones do you need? You need the center vents which house the clock and hazard/defrost switch?
Old Nov 13, 2006 | 10:57 PM
DjMoney's Avatar
I believe it's the drivers side in the back.
Yea.
Old Nov 13, 2006 | 11:34 PM
Maxima_Joe's Avatar
4th Gen Parts King
Yea.
Well theres three o2's total. Theres two in the y-pipe.One for the front bank one for the rear bank. Then there is one right after the catylatic converter.
Old Nov 14, 2006 | 05:16 AM
DjMoney's Avatar
I'll check again to make sure than I'll let you know
Old Nov 14, 2006 | 06:23 AM
maxihari77SE96's Avatar
I need an O2 sensor - fron and a crank position sensor?
How much to 60640?
Also, how many miles on them?
thanks
Old Nov 14, 2006 | 10:07 PM
Maxima_Joe's Avatar
4th Gen Parts King
How much to 60640?
thanks
$40 shipped for both 116,000 miles
Old Nov 15, 2006 | 05:40 AM
Marl1979's Avatar
How much for Knock Sensor and Front Heated Oxygen Sensor (Right Bank) shipped to Montreal - Canada @ H4N2T2 ?
Also, those will work on a fed. 99 SE right?
Old Nov 15, 2006 | 09:27 AM
rypace's Avatar
Got a crankshaft pulley?
Old Nov 15, 2006 | 05:55 PM
NyC97Max's Avatar
sent you a PM regarding a previous request (EVAP purge control valve) as well as also a knock sensor, thank you
Old Nov 15, 2006 | 08:37 PM
Maxima_Joe's Avatar
4th Gen Parts King
Yes they will work on your 99. $70 shipped
Old Nov 15, 2006 | 08:38 PM
Maxima_Joe's Avatar
4th Gen Parts King
Yes i do $30 shipped
Old Nov 16, 2006 | 05:18 PM
MOHFpro90's Avatar
Knock sensor? Any clue on condition? I am looking for one to test and see if my KS is faulty...thanks!
Old Nov 16, 2006 | 06:14 PM
Maxima_Joe's Avatar
4th Gen Parts King
Yes i still have knock sensors. 100% working condition.$40 shipped
Old Nov 20, 2006 | 06:30 PM
Maxima_Joe's Avatar
4th Gen Parts King
Old Nov 21, 2006 | 06:46 PM
bumping96's Avatar
How much wuold it be for the camshaft position sensor shiped to 93552?
Old Dec 6, 2006 | 09:09 AM
Maxima_Joe's Avatar
4th Gen Parts King
The engine is completly disassembled.Anybody need anything?
Old Dec 17, 2006 | 12:41 AM
maxrollingon20s's Avatar
got any 5spd trannys?
Old Dec 17, 2006 | 03:28 AM
glenmoormax's Avatar
10 psi
timing equipment/cover and anything related to the timing for the 3.5 swap
Old Dec 19, 2006 | 08:52 AM
MAXSE5SPD's Avatar
flywheel, more specifically the timing ring?
Old Dec 19, 2006 | 11:47 AM
alex19's Avatar
got a code 47 & code 34 i need Crankshaft Position sensor (ref) maxima 1995 GLE, knock sensor, starter,passenger side tie rod & all 4 bose speakers,
also need passenger side wheel bearing (with hub) for 2000 maxima GLE if u have
give me price on all this shipped
thanks
Old Dec 19, 2006 | 12:12 PM
jmeister's Avatar
Any black interior pieces? Need C pillar, where seat belt goes through, drivers side
Old Dec 20, 2006 | 01:36 AM
Maxima_Joe's Avatar
4th Gen Parts King
No manual trannys
