What did you guys use to seal MAF->charge pipe?
Old Dec 5, 2006 | 03:11 PM
RichMax's Avatar
Boosted like Snipes tax refund
I finally got to a mechanic with a smoke machine. I found about 5 separate leaks, one of which was around the MAF where it connects to the charge pipe. My question is, what did you guys put between the two surfaces where they mate to provide an air seal? How effective was it and where did you get it from?
Old Dec 6, 2006 | 01:18 AM
ewuzh's Avatar
There's supposed to be a rubber o-ring that goes in between the maf and whatever you bolt on to it. If you look at the MAF, you will see the little crevice for it. You can prolly get one at the nissan dealer.
Old Dec 6, 2006 | 06:47 AM
abci30's Avatar
oh noes!!!!1111
i also have a gasket(cork) inbetween the maf and charge pipe along with the O ring.
Old Dec 6, 2006 | 06:56 AM
RichMax's Avatar
Where did you get that from locally? Believe it or not, I have been having one hell of a time finding gasket material at PepBoys and AutoZones around here...
Old Dec 6, 2006 | 07:12 AM
abci30's Avatar
oh noes!!!!1111
i got a whole roll at advance auto. Its in the same row as rtv and thread sealer.
Old Dec 6, 2006 | 07:54 AM
matty's Avatar
That large Nissan O-Ring should be enough for sure unless they are not mating on a good angle...do it off the car so it mates perfectly....if you do it on the car with it connected to the blower, it will pull down on one side of the maf..
-matt
Old Dec 6, 2006 | 08:29 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've had that problem too and so I've been using PERMATEX® High-Temp RTV Silicone Gasket Maker.
You can also look for a replacement O-ring. I picked up a non-Nissan O-ring and it was the right diameter but thicker rubber.
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
raffivegas
Aug 23, 2015 09:54 PM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
