Coolant Temp Sensor
Old Dec 18, 2006 | 04:55 AM
rich in co's Avatar
Coolant Temp Sensor
Okay folks I have been reading some older threads, and even in the threads I started about my wifes 92 a lot of folks say replace the Coolant sensor.
From reading the threads it seems that the coolant sensor is prone to go out on these cars.
What is the world does the sensor do, and why would it be the cause for so many issues. Is it a running joke or is there really some issues? I,m guessing that when it goes out it can cause some electrical cross reading and can confuse other sensors. Also if the coolant sensor is bad should'nt the ecu throw a code.
Old Dec 18, 2006 | 05:21 AM
Greeny's Avatar
¯\(°_o)/¯
The cts measures the coolant temperature,then relays this info to the ecu so it can adjust the fuel mixture until the engine warms up,cold engine= open loop mode[rich fuel]
warmed up engine=closed loop mode..
And it also lets the ecu know when to turn on the cooling fans when the engine gets ubove a preset operating temperature.
So yeah,if it is bad,it could relay false information to the ecu,causing it to adjust other sensors/parts incorrectly...
These cars rarely throw a cel for anything,even if the part is malfuntioning.
Old Dec 18, 2006 | 06:50 AM
Cliff Clavin's Avatar
Way out West
My CTS went out and it threw a code.
The sensor is only about $20 and takes <5 minutes to replace.
Mine had a very erratic idle and the fans would kick on and off randomly.
Old Dec 18, 2006 | 07:14 AM
Greeny's Avatar
¯\(°_o)/¯
You're one of the few..
This past summer my maf died,no code was stored at all.
Old Dec 18, 2006 | 08:54 PM
Way out West
On your VE or VG?
Just curious, because it seems like the MAFs conk out on VGs more often. When I first got on the .org, a lot of people told me they went out, so I picked one up. It has been sitting in my garage for over 3 years.
Old Dec 18, 2006 | 09:13 PM
Hectic's Avatar
On your VE or VG?
you have to drive your car in order for it to eventually fail
Old Dec 18, 2006 | 10:42 PM
Way out West
I did. I drove it to work one day last week.
Exactly 4 miles round trip...I let it warm up for 20 minutes when I got home to charge the battery, though. I need to start it again this week. The high temps have been in the low 30s.
Old Dec 19, 2006 | 02:58 AM
internetautomar's Avatar
mod or sell?
I've got a spare in the garage now too, 4 maxs and none have needed one so far. I'm not worried about jinxing myself, the spare is in the garage.
Old Dec 19, 2006 | 04:43 AM
Greeny's Avatar
¯\(°_o)/¯
On your VE or VG?
The VE...I cant complain though,it made it to 300,000 miles before it died..
Old Dec 19, 2006 | 03:34 PM
ColombianMax's Avatar
Pff I've had both MAF and CTS bad, MAF came bad with the car and wouldn't let rev past 2k rpms (thats why I got it cheap) and the CTS went out when when I recently got the car as well, damn fans wouldn't kick in and once again NO CEL.
Old Mar 8, 2007 | 04:46 AM
frumundacheese's Avatar
Jumping Coolant levels
I'm thinking my coolant sensor is bad. My temp sensor needle jumps sometimes while I'm driving. Its almost like its flickering but it reads almost correct when it sits still. It never goes high. Is it worth replacing? It's not tied to the throttle sensor is it? The previous owner got a code for the throttle sensor, replaced it and the code came back. I just left that code and ride with it. My speedo is correct because it matches my GPS.
Old Mar 8, 2007 | 04:55 AM
Greeny's Avatar
¯\(°_o)/¯
Your info says you have a 96=4th gen..Is this the car we are talking about?
Old Mar 8, 2007 | 08:08 AM
Alex_V
w/e max you have bleed your cooling system.
~Alex
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
