Idle adjustment procedure for '93 vg30 SOHC
Old Jan 8, 2007 | 09:50 AM
redwood_usa's Avatar
Anyone have the FSM directions for adjusting the idle speed on the vg30. the postings on this site differ .
Old Jan 8, 2007 | 10:27 AM
Pearl93VE's Avatar
I can has?
Stole this picture off an ebay sale*
The thing circled is your IAC on a VG. It has a little black spot on it with a rubber insert, take off the black rubber insert and you'll find a screw beneath it. The screw adjusts the idle.
edit: wooppsiiesss.... (pic)
________
Philippine girl Webcams
Old Jan 8, 2007 | 10:45 AM
I know where the screw is , but you can just turn the screw. there is a procedure that requires other stuff to be done if you want to adjust the idle properly.
Old Jan 8, 2007 | 10:48 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jan 8, 2007 | 10:49 AM
Greeny's Avatar
¯\(°_o)/¯
Nice picture..
Old Jan 8, 2007 | 10:53 AM
Greeny's Avatar
¯\(°_o)/¯
What is the engine doing?
Idling too high/low/stumbling?
Old Jan 8, 2007 | 11:19 AM
goon9's Avatar
You really need to buy and FSM. We can't legally post pieces from one.
Also. You cannot just turn the screw, you need to turn off the AIC Valve by turning the screw on your ecu all the way clockwise. Then race the engine a few time, let it idle for a second, turn the screw until it it's around 750 rpms. Race it few times, check it. Turn the ecu back to counterclockwise. Restart the car, check idle.
Only do this if the idle is consitantly higher, or lower. Not if it is idle rough.
Old Jan 8, 2007 | 12:17 PM
OK this is almost what I am looking for - Please clarify some points.
1. Do I turn the ecu screw clockwise when the engine is running or before I start it.
2. Do I turn the screw back with the engine running ?
3. there are some who say that you have to put the ecu into self diagnosis mode 3 and not off before doing this ? Any idea about this
Old Jan 8, 2007 | 01:07 PM
Pearl93VE's Avatar
I can has?
Hmm, weird. I didn't know that. I just turned the screw in the engine bay and noticed a change in idle?
________
Cat wheels
Old Jan 8, 2007 | 01:48 PM
goon9's Avatar
When it is running
Yes
You don't need to. You can run it if you want.
Old Jan 8, 2007 | 04:15 PM
92 Max's Avatar
Here's a link to autozone, where the procedure is described in the repair guide, tune up part of the site.
http://www.autozone.com/servlet/UiBr...5c.jsp#hd1-1-1
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
