Replacing belt tensioner assembly: Cost?
Hey guys,if i had to replace my belt tensioner assembly how much would it cost,because of a bolt snaping not on the pulleys i think the adjustment bolt,i was trying to turn it when trying to remove alternator.Im still going to see if i can fix it but what would it cost for a new assembly.unless anyone has the peice for me for like 5 bucks.
do you think id be able to drive my car to my buddies place.its about 15 mins away from my house.if i drive there we will be able to fix everything.but i dont know if ill be ok with that broke
so how long you thing a non charging battery at full charge would last?i need to get to my friend garage
I wouldnt anticipating it lasting more than 5 minutes.
The tensioner pulley assembly is the same for all 95-04 Maximas. Maybe even later.
Get one from a junkyard or from www.courtesyparts.com, or www.pinnaclenissan.com. part is ~ 43$
make sure the rear bracket is still in good shape since the tensioner pulley comes separate.
You can drive it for a short distance if you have good battery power. I drove 35 miles one time (~45 mins) w/o one.
Great i guess ill have it towed
I got the part after that i needed from nissan. costs 26 bucks.Its the adjustment bolt and the peice that screws into the bolt.As for driving the car,even tho the bolt cracked its still solid and only a couple nuts and such are took off my alternator but its not off.And when it comes to reving the car, its an auto so no reving like a 5spd(i wish it was 5spd).I charged my battery all the way up and i have to go about 15 mins.I think i can make it
O I just realized the bracket on the assembly the top of it is where it was turned and it cracked. thats the only thing other the that its all still together and even that bolt didnt come out of the bracket.
check here it don't show on picture but comes with the tension bolt with shipping it cost me 54.99
http://www.courtesyparts.com/Merchan...de=11925-ACPUL
I got everything i needed for the 26 bucks from nissan and im going to fix my car when i gets a chance
tsi6001
Oct 3, 2022 10:23 PM
FlaMark
25
Aug 28, 2015 10:15 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
kirkhilles
Aug 8, 2015 10:53 AM
