TSX projector retrofit
I was wondering if this is all I need for a complete retrofit (minus the headlights)
http://cgi.ebay.com/ebaymotors/Acura...spagenameZWDVW
Is there anything else I would need?
you will probably want to get a shroud.
a shroud is something that goes over the front of the projector to make it look good and properly flow with the headlight.
u will also want to make a wiring harness to get the power directly from the battery.
other than that...that set is complete.
Originally Posted by riceyasian86
Where would I get the wiring harness from? Could you tell me the type of harness to purchase?
I've never done a retrofit so I don't know which harness to get.
basically how it works is u need to have a relay. The stock plug sends a signal to the relay to get power from the battery. I got mine from HomerMAC. They cost from $30 from him.
The link has everything you need, I personally prefer a different ballast, one that is not as bulky. A wiring harness can be made by yourself for $30-$40, I can help you out with instructions if you need it, start with a 5-pin SPDT relay and 16 gauge wires in a few colors (2 minimum).
The relay is part of the wiring harness, it takes the signal to turn on via your factory headlight wiring, then takes power direct from the battery, and sends it to your HID ballast. So you bypass the factory wiring to power the ballasts, and avoid frying your wires, while providing the most direct power available.
Maxima_Joe
Nov 25, 2015 08:19 AM
03VQMAX
Nov 10, 2015 03:39 PM
umnitza
Sep 1, 2015 01:03 PM
