Plugs are showing lean
Old Feb 21, 2007 | 05:25 PM
Mynameismcgyver's Avatar
I pulled 3 plugs today and they are quite white. Gap is correct at .44
2001 Gle with 125,500 miles on it. Wondering if I should go ahead and replace the filter that is in the tank. Any opinions?
Old Feb 21, 2007 | 05:33 PM
upstatemax's Avatar
Your Mcgyver... You can fix it with a Turkey Baster and a tube of chapstick.
Old Feb 21, 2007 | 05:40 PM
LOL. I was thinking along of the lines of Play Dough and Toothpics.
Old Feb 21, 2007 | 05:46 PM
upstatemax's Avatar
Hey, YOUR Mcgyver... It's up to you.
Now what are you going to blow up while your plan unfolds to perfection?
Old Feb 21, 2007 | 05:50 PM
upstatemax's Avatar
On topic...
If you have not changed your fuel filter it is a good idea to start there... I would also check the MAF and coils.
Old Feb 21, 2007 | 05:53 PM
I also got a P0420 Cat below efficiency bank 1 1 hr ago as a matter of fact. Not sure if it has anything to do with it. Cleared it though.
Old Feb 21, 2007 | 05:56 PM
upstatemax's Avatar
If it is comming from one of your primary o2 sensors it WILL mess with your AFR, usually once your CEL comes on for them your car goes into default mode, and default mode is to run rich...
Old Feb 21, 2007 | 06:01 PM
Well lets put it this way. I checked the plugs BEFORE the CEL came on. The light has never come on before. If I keep getting the light, Bank one is which O2 sensor? I believe there are two?
Old Feb 21, 2007 | 06:06 PM
upstatemax's Avatar
If you are Cali (I would bet on it) you have four o2 sensors... Two primary and two secondary. The two primary ones control fuel delivery and if your sensor is going out it will mess with AFR. Bank 1 I THINK is the rear bank.
Old Feb 21, 2007 | 06:09 PM
I live in North Caro (Used to live out by you on Long Island to which I am visiting tomorrow). So Im guessing I have just two O2's
Old Feb 21, 2007 | 06:13 PM
upstatemax's Avatar
Does not really matter where you live... Almost ALL 01's are Cali spec.
Old Feb 21, 2007 | 06:17 PM
Oh gotcha. Well I appreciate the help! I am going to replace the fuel filt tomorrow for ****s and giggles. Ill go from there.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
