Sponsored by:
Sponsored by: CARiD
Nooberish Cam Timing Question
Old Feb 28, 2007 | 09:25 AM
95naSTA's Avatar
On a 3.5 swap,
Using the 3.5 timing stuff
Pretending that the TVCs are locked in the right position
And trying to use a vq30 ecu
Do the different cam sensors (rear heads vs timing cover) make the 30 ecu unable to control it?
The cam timing signals are different, correct?
Am I missing any other problems?
Old Feb 28, 2007 | 10:18 AM
nismology's Avatar
You have to use the 3.0 timing equipment to use the 3.0 ECU, period.
Old Feb 28, 2007 | 10:21 AM
95naSTA's Avatar
Wow, thanks for the amazing answer.
How about actually answering my questions instead of being Mr. COCKy.
Old Feb 28, 2007 | 10:24 AM
nismology's Avatar
The fact that you don't like my answer doesn't make it any less true or relevant. The 3.0 ECU needs to read the bumps on the main intake cam sprocket to determine which stroke the #1 cylinder is on. Without that, it will never run.
Better?
Old Feb 28, 2007 | 10:38 AM
95naSTA's Avatar
I don't just give up when someone says there is no way..
Yes that answer was much better, I just wanted to verify the cam signals were different and now I know.
JClaw's Avatar
Lol *** jokes in the all motor forum. The only reason to use the full 3.5 with the ugly cover is VTCs. If you start modding crank-cam sensor positions and timing covers you will truly want to buy yourself a gun and shoot to kill. Believe me.
Old Mar 2, 2007 | 04:58 PM
oTranscendental's Avatar
Is there no way to use a PWM box to power the solenoids? In combo with a piggyback? (all with 3.0 timing cover and ecu)
Old Mar 2, 2007 | 06:59 PM
nismology's Avatar
Driving variable cam phasers isn't like driving injectors. To correctly control cam timing there has to be a brain that knows exactly what the cam position is at all times to keep it close to the target value and is constantly comparing actual to theoretical to make changes based on that. Simple things like oil pressure and viscosity would be enough to throw the cam timing off without feedback control.
Old Mar 3, 2007 | 04:45 PM
So basically there is no hope for us 3.0 TC guys. What a let down.
How much of a gain would we get from an rpm switch for the 3.5 VI?
Old Mar 3, 2007 | 06:06 PM
MDeezy's Avatar
it wasnt really a cocky answer, its been stated many times the 3.0 equipment needs to be used when your retaining the 3.0 ecu.
If you are determined enough by all means lead to way and show us a way to make it all work, were all open minded here, but we do know when were beating a dead horse.
Old Mar 4, 2007 | 06:30 PM
95naSTA's Avatar
Originally Posted by MDeezy
it wasn't really a cocky answer, its been stated many times the 3.0 equipment needs to be used when your retaining the 3.0 ecu.
It was cocky IMO
This is all I wanted to make sure of:
And I wanted to make sure that was the only snag.
But I got:
I know you use the 3.0 timing equipment to use the 3.0 ecu. I just finished swapping it over on my friends 3.5 not to mention got spacers made on my own for much cheaper and went with him to Tilley's to have the cams drilled slightly retarded compared to the vq30DE cams per my request.
I understand why you can't use an additional injector driver or rpm switch.
I've been through all that.
It would have took less energy to write 'correct' and 'no' and I would have gotten more out of it.
Old Mar 4, 2007 | 06:34 PM
nismology's Avatar
Bottom line: If it was possible to use the 3.5 timing equipment with a 3.0 ECU it would've been done a long time ago.
Old Mar 4, 2007 | 06:42 PM
95naSTA's Avatar
If it could have been done easily it would have been done by now.
Old Mar 4, 2007 | 06:58 PM
GoalieKeg's Avatar
It is easy. Run a megasquirt, and bulid everything yourself. You'll be able to have a 3.5 w/VTC's and a 5spd tranny. Done deal. I hope you know how to engineer.
What I'm trying to say is, you will need to have a board built to utilize VTC's.
Old Mar 4, 2007 | 07:31 PM
Lefteezy
if youre up to doing that much work to use the 3.0 ecu, then why not just use an a33b ecu and not have to worry about it not working?
Old Mar 4, 2007 | 11:33 PM
I read a post about using both ecus together but you would have to splice the harness to both, and for guys with the 3.0 TC I'm not sure if VTC would even work.
You would just have to run all the 35 wires and ecu.
I must have more powah! I must find a way to get vtcs working
Old Mar 5, 2007 | 05:39 AM
abci30's Avatar
oh noes!!!!1111
Last time i checked he is an engineer but that could have changed maybe he wanted to be a cop this week.
Old Mar 5, 2007 | 10:22 AM
95naSTA's Avatar
I do have two ideas.
Both would use the 3.0 ecu and you wouldn't have to take off the 3.5 timing cover.
One involves a lot of machining and the vq30 timing sensor but no VTCs.
The other involves either a pic or a stamp to actually control the VTCs but then I'm not sure how to get the timing signal.
I'm just going to see how far I can get with it but at least I'm going to give it a shot.
Old Mar 5, 2007 | 10:26 AM
MDeezy's Avatar
best of luck. post up your findings.
Old Mar 5, 2007 | 11:50 AM
VQ'ed's Avatar
good luck also as it is somewhat unknown in the community, what your trying to do that is.
kjlouis
Nov 24, 2018 06:09 AM
max_speed97
Aug 26, 2015 07:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
95naSTA
Aug 16, 2015 05:03 PM
95naSTA
Aug 16, 2015 05:02 PM
