This is why untuned 3.5's need to get a fuel adjustment program.
Finally got the WB hooked up and did some runs. Here is the first run. No corrections done:
10.1 AFR! I'm using SAFC-II but so far with -15% removed at all rpms has brought it closer to 12 AFR. Obviously I have a ways to go, but this is a good reason to consider some kind of fuel computer. I'm considering EU now as I would like to trim fuel under 40% throttle.
I'm in the same boat as you though about the EU, strongly considering it.
yup, 10s and 9s are not rare on a 3.5 swap with no tuning. I think i have -19% - -20% at 4500 IIRC. I use an SAFC-1 and it works just fine. Of course eventually I want to get an EU, but really as far as fuel control is concerned, SAFC is enough.
look in sig no fuel tune ,no timing tune and stock rev limit .
I have no clue what my air fuel ratio is ,my swap was done around 3 years ago. i think i smell fuel when i drive
, lol. Hey you're very aware that if it was actually tuned it would run even better than it is now. You have amazing #s with no tuning... imagine tuned :-D
Well here is the latest:
Looks alot better than the original. I have a few areas to clean up but much better. I'm trying to stick around the 13.0-13.3 range. The transition from the low rpm to high rpm with the gutted IM is not as drastic as it was before the change. Downside is with the changes is a nasty torque steer. I need a AE tranny.
Harry, I still plan on going to the dyno when I get this sorted out. I'm thinking next month.
Originally Posted by MaxBlack97
what r u using 4 ur extended rev limiter, if u have one?
Why tune under 40% throttle?
Do you hava data to prove you're rich at ≤ 40% TP as well? If so, you may have other issues (o2 sensors) since they (O2 sensors) should adjust and be very close to stoich during that condition ( ≤ 40% throttle)[/QUOTE]
yikes. I smell fuel alot when I get on it when I'm driving, but normal driving my working o2, help out there.
untune, yea.
Originally Posted by nismology
I have a feeling that the whole 51 PSI thing is unnecesary.
Let me know about dyno plans. I'll take movies!
Originally Posted by grey99max
Traction bars solve torque steer. Remember mine ??? A VLSD tranny is always good - you can get them out of 1995-2001 Infiniti, or AE 2001 Maxima, or 2002 V6 Altima. But the Jbars solve torque steer. More power causes that, you know.
all 06 altima 5spd trannies come with a VLSD?
Here's mine. I didn't need too much adjustment initially since TS did a pretty good job (12.8-13.1) so far.
I leaned it out a bit though.
Needs more smoothing though.
About (-)4-6% across the board w/ SAFCII
I have this extremely lean spot only in first gear from 3900 - 4100.
So when I correct it, it does fine in 1st, but in 2nd and all other gears, it's rich in that corrected (+) area. So,
I only know that some 2002 V6 Altimas have "locking" differentials as shown in a Car-Part.com search for automatic transmissions - in V6 cars. I've didn't find any locking differentials in 2003-2008 Altimas.... but I didn't look very hard, since any 5-spd automatic won't fit in my '99 Max.
Originally Posted by Subzero
who makes traction bars for our cars?
http://forums.maxima.org/showthread.php?t=417318
http://forums.maxima.org/showthread.php?t=412049
Also, what's up with the lean A/F in the 7000 rpm range. That is a little dangerous don't you think. I'm not familiar with the 3.5 but can it handle those lean conditions like that with no detonation?
Originally Posted by speed racer
The same **** happens with me when I step on it from a dig. It does this funky SIN and than stablilizes. I tried fixing mine and it just takes small adjustments to minimize the lean condition.
ing of timing in higher RPM) But my ECT has risen a touch during normal driving.But, on that subject, there are people on here tossing timing into the high 30's to around 40 w/o detonation using the VQ30, so
I know mine would always ping when i had my JWT and the weather was warm (mid 70's or greater)
If you're asking me, I don't know that.
90-95 Nissan Stanza/Altima has a VLSD tranny that is similar to the 5spd Maxima tranny. It won't bolt up.
Car-part.com is wrong.
Originally Posted by BlackBIRDVQ
2002 Altima uses a cable operated transmission that is similar to that of the 2002+ Maxima 6spd. Its not the same tranny.
About the 2002 V6 Altima - the FSM shows two different automatics for that year - one is a 4-spd automatic that sometimes shows as "locking". The FSM seems to show an identical tranny to 4th-gen automatics.
So you can find 95-99 Infiniti automatic VLSDs, 2001 AE automatic VLSDs and 2002 V6 Altima automatic VLSDs listed on car-part.com that may slide in the 4th-gens. Verify the tranny part number.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
