GI:vg33e and mods for sale
I don't have the time to mess with my maxima anymore, so I'm seeing if I can peddle some of this stuff; perhaps someone wants the whole car??
1989 Maxima, baby blue and kinda rough. vg33e(73K miles on it) out of a 1997 infiniti qx4 converted for maxima use, 2 1/2" exhaust, y-pipe, exedy 3 puck clutch(60 miles on it), fidanza flywheel, 1993 ve5 LSD transmission, hubs, axles, drilled and slotted brakes, relocated battery(trunk)...
The brakes don't work well at all, the injectors are off of a vg30, so it doesn't get enough fuel, it needs starting fluid to get it started on cold mornings. The car won't start with the key, it has to have the starter crossed manually, may just be an ignition switch. I'll include a full gasket set and 270cc injectors out of a ve, along with a trunkload of goodies. i also have a set of 550cc injectors and rails off of a 1990 300zx tt. I'm open to fair offers.
Originally Posted by therealgoon9
I can just take it if you really want it gone
I may be interested, since I want to go with a V33ET conversion or swap anyway in the future. I have an '89 VG auto right now- looking to go 5spd(VE-LSD), RearDisk, Turbo... So, how much for your car as a parts car? and How much for just the parts I need? My concern would be with the runnability. What will it take to get it running smoothly? Will it fit nicely? Thanks,
-Mrkanda
-Mrkanda
-Mrkanda
-Mrkanda
Guys, if starting is an issue for some of you with this car, something to consider is paying $20 and getting a push button start. Simply bypass the ignition switch given it seems that it is turning on all the electronics (fuel pump, coil, ecu, etc.). Outside of swapping injectors, a FPR or upgraded fuel pump would likely help with what the engine has now. Upgraded injectors would definately be a need if boosting. Sounds like a nice project car, good platform to build from. Work sounds minor to me, but we've yet to see the car in all it's glory!
Thanks for the input, I still don't have a camera. Some kid also yanked the two power lines going to my battery out of my car last week, so it needs those, which I will also supply.
engine 67120 miles on it-700 shipped to business address
ve lsd Trans 123K on it-400 shipped
exedy stage 3 puck clutch-less than 100 miles on it-120
vg fidanza flywheel less than 100 miles- 220
magnacore plug wires 40 shipped
koyo performance radiator >100 miles-65 shipped
drilled and slotted rotors 80 shipped
ss clutch line 15 shipped
-------parting out--------
engine 67120 miles on it-700 shipped to business address with new gasket set
Do you have any other pics of the rest of the body and interior? Also, does this car have the rear disks? I'm still considering buying the whole thing- depends on sale of my van. Thanks.
Yes, it's an SE, rear discs. The hubs are off of a 92-94, so even if there weren't abs, which my car came with(removed it), the spindles could still be, Goon. Think I have an abs one laying around, I'll check. No other pics. The hood and bumper have been sold.
Originally Posted by nismosleeper
No, it is being parted out. The front end is almost gone, but the engine and trans are still intact.
I may be interested in just the block. Do you have any details about it?
I'm trading it to my boss, but I'll check out his core for you when he switches them out.
100 for the stage 3 clutch
200 for the flywheel
350 shipped for the transmission
140 for eibach pro-lines (springs)
20 for new felpro gasket set
70 shipped for each head off of a vg30e
50 shipped for a pair of monroe struts, 200 miles on them
It's ok, I'm no longer needing a 3.3
maxima-junky
Oct 7, 2015 06:13 PM
