Long Story.. Long Night... Maxima Died...
Old Apr 21, 2007 | 11:39 PM
nForce's Avatar
The Computer Guy
So I was hanging out with friends as any other teen would do on a Saturday night driving around going to parties when I come around a sharp turn and here a LOUD metal creaking sounds from front drivers side wheel area (had my window down) I didn’t think much of it thought of it as maybe something on the ground when all of a sudden I smell a tremendous about of oil burring. So I look in my rear mirror and see a HUGE cloud of smoke coming out from my back end. I thought "please not a blown head gasket" I pull over to the side and see a HUGE trail of oil from tranny that traces back to the turn. As I look at the tranny its gushing out like someone turned a hose on full blast. So then I waited for 45mins for the tow truck to take me and my maxima back to my driveway. So now I post this on the org for you all to give me advice and help. I am car less and extremely PISSED OFF right not. So if anyone has advice please post...
Now I will go and be pissed off
nForce
Old Apr 21, 2007 | 11:45 PM
maxitech's Avatar
Trace where it is coming out of the tranny...Does it still shift fine? Pics and info needed...Alex, what did you do? J/K
Old Apr 21, 2007 | 11:51 PM
Alex_V
Wow man that sucks ***. Here I am worried about my ISB dieing soon and you have holes in your case....bummer man. I wish I could help :/
~Alex
Old Apr 21, 2007 | 11:56 PM
nForce's Avatar
The Computer Guy
I did shift fine but wouldnt let me into Reverse but I stopped driving it when I noticed the huge smoke cloud.
nForce's Avatar
The Computer Guy
It was pouring out from were the flywheel meets with the tranny. If that helps any..
Old Apr 22, 2007 | 12:12 AM
x91max
was it transmission oil or motor oil?
Old Apr 22, 2007 | 01:48 AM
Tom's Avatar
Tom
If you're lucky, one of the transmission cooler hoses broke and sprayed ATF all over the place, esp near where you describe. R&R hose & refill transmission with ATF. That's the best case scenario.
If not, well, it can be all kinds of things....
Old Apr 22, 2007 | 01:53 AM
Greeny's Avatar
¯\(°_o)/¯
Sounds like one of your axles slipped out of the tranny,or that crack got really big,really fast..
Oh..edit: leaking around the bell housing?.....Not good..
Old Apr 22, 2007 | 01:54 AM
Greeny's Avatar
¯\(°_o)/¯
He has a manual tranny...
Old Apr 22, 2007 | 11:03 PM
Hectic's Avatar
I wouldn't say it's dead. More like an injury. I'm going to guess something is screwed with the reverse lever assembly which jarred the input shaft and caused the leak. The lever deal is right next to the input shaft and the reverse gear meshes with the input shaft when you throw it in reverse. There's a couple springs and a ball that are part of the reverse assembly and if not set correctly would explain why you're locked out of reverse and also might allow the reverse gear to slide and hit the input shaft gear when it's not supposed to, which could have broke stuff and caused the leak. Again, it's just a guess, this isn't something anyone can positively diagnose over the net, you're going to have to crack open the tranny to find out for sure what's wrong.. Good luck man...
Old Apr 23, 2007 | 02:18 AM
ColombianMax's Avatar
Damn dude that really sucks...I knew that damn Alex was up to no good lol...
Looks like I might be driving down there this time to give ya a hand as long as I got gas
Old Apr 23, 2007 | 04:49 AM
nForce's Avatar
The Computer Guy
If you and Mygreenmax94 come down we should have no problem fixing this up in a day or two . Im thinking ill have to get another tranny..
Old Apr 23, 2007 | 04:55 AM
maxitech's Avatar
There is a surplus of VE 5-speeds in Tulsa, OK...
I think I might pick one up, myself...
Old Apr 23, 2007 | 07:19 AM
internetautomar's Avatar
mod or sell?
is there a front seal on a manual trans?
sorry I never looked, don't care either. but that is where I'd start if there is one.
Pray for the best, plan for the worst
Old Apr 23, 2007 | 07:56 AM
Matt93SE's Avatar
STFU n00b!
there is a front seal (input shaft), but unless you WAY overfilled the fluid, it shouldn't come pouring out like that.
the mainshaft could have popped through the case into the bellhousing like mtcookson's (???? was that who did it?), but otherwise I dunno.
what type of fluid was it? you never clarified that.
If it's pouring out between the engine and bellhousing, it could be oil or tranny fluid.
based on the smoke, I'm going to guess it poured all over your Y pipe too?
Old Apr 23, 2007 | 09:56 AM
nForce's Avatar
The Computer Guy
The oil that came out was tranny oil. The dipstick was at its nornal level. The oil was coming out from were the tranny meets with the engine. I have pictures im uploading now. The flywheel has oil all over the teeth (you can see in pics) so im guessing its a large leak. The road I was on has a oil trail for about half mile so it has to be a large crack of some sort. The oil was Pennzoil Synchromesh
Old Apr 23, 2007 | 10:04 AM
nForce's Avatar
The Computer Guy
nForce's Avatar
The Computer Guy
Old Apr 23, 2007 | 10:21 AM
mtcookson's Avatar
The shaft that the throwout bearing slides on broke on mine but it definitely caused a good oil leak. I'm pretty sure it was due to driving on a broken input shaft bearing for way too long (this was around when I first got the Max so I didn't know that was the issue at the time, was constantly told it was the tob... boy were they wrong ).
Old Apr 23, 2007 | 11:02 AM
nForce's Avatar
The Computer Guy
If that broke would I have still been able to drive it? After I herd the sound when I was driving I drove half mile before I could pull over. The tranny shifted perfectly fine all the way to 5th.. Any idea?
Old Apr 23, 2007 | 01:23 PM
maxitech's Avatar
Just throwing it out there: I noticed you don't have the dust cover over the flywheel...Maybe something got in there? Never heard of your specific situation before, so anything is possible...
Old Apr 23, 2007 | 01:35 PM
Matt93SE's Avatar
STFU n00b!
can't tell squat from those pics. you're gonna have to get the tranny out to tell anything.
Old Apr 23, 2007 | 06:03 PM
mtcookson's Avatar
Yeah, mine would still drive. Only problem was the clutch was a little more difficult to press and it leaked gear oil pretty bad.
Old Apr 23, 2007 | 07:01 PM
nForce's Avatar
The Computer Guy
Im gonna take the tranny out wednesday so hopefully ill get some pics up. My clutch pedal is the same as it was before. So im hoping its just seals.
Old Apr 23, 2007 | 07:15 PM
x91max
your probably going to need a new clutch.
Old Apr 23, 2007 | 07:17 PM
nForce's Avatar
The Computer Guy
hope not... I just got this one it only has 500 miles on it
Old Apr 23, 2007 | 07:44 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
in the 2nd pic is your boot rubbing on that bracket next to it? (what is that? a belt tensioner? ugh, 2d pics are totally crappy, that's why humans have 2 eyes to see 3d... makes it so much easier to discern things.)
Old Apr 23, 2007 | 07:52 PM
nForce's Avatar
The Computer Guy
no the boot is not rubbing in the 2nd pic. The 2nd pic is just show that the oil from trany made it all the way over to the other side of engine. Once I get I get it running again im gonna have to do some SERIOUS cleaning..
Old Apr 23, 2007 | 10:02 PM
Dude theres ve tranny at my local u pull it but its AT
Old Apr 23, 2007 | 10:53 PM
maxitech's Avatar
How does that do him anygood?
Old Apr 23, 2007 | 11:27 PM
lol, it doesnt but it just shows him that at least my yard is close to the VE world :P He did ask me to keep an eye for VE5s in the JY so I shall.
Old Apr 24, 2007 | 12:03 AM
Jon94SE's Avatar
Isn't his car a GXE?
Old Apr 24, 2007 | 04:37 AM
Alex_V
When we swapped it we used a ve-5 donor...so he needs another ve-5 tranny.
~Alex
Old Apr 24, 2007 | 08:25 PM
nForce's Avatar
The Computer Guy
started taking it all apart today almost done just have to unbolt tranny and drop it out..
Old Apr 25, 2007 | 12:35 PM
damn son, you know what you're doing?
Old Apr 25, 2007 | 01:00 PM
nForce's Avatar
The Computer Guy
Yea its really not that hard...
Old Apr 25, 2007 | 01:03 PM
nForce's Avatar
The Computer Guy
I got new toys for the job and they werent expensive at all take a look all under 170 bucks...
Old Apr 25, 2007 | 01:18 PM
Greeny's Avatar
¯\(°_o)/¯
meh..i prefer craftsman...
Old Apr 25, 2007 | 01:27 PM
mod or sell?
is that stuff from pep boys?
Old Apr 25, 2007 | 01:46 PM
nForce's Avatar
The Computer Guy
nope Costco Wholesale
