FS: VG/VGT/VE Parts
Old May 5, 2007 | 10:36 AM
Chris Gregg's Avatar
Get Off My Lawn
FS: VG/VGT/VE Parts
Make me an offer! Email me directly for questions: Mxmumpwr@aol.com
** LIST UPDATED 10-28-07 **
Misc. Parts: (VE/VG)
Fuel pump..............A/C/heater blower motor.............Analog climate control
Brake booster...........Rear ABS sensors.......................ABS ecu
Deck lid(drk/gry).......Hood(drk/gry)............................Air bag system
Cruise control...........Stock corner markers L/R.............Coolant resouvior
Radiator...................Doors and window glass..............Windsheild cowl
P/S pump.................P/S resourvior............................Left rear bose amp
'89 side mirrors..........Trunk/gas lid release switch.........Bose 6x9 brackets
Cup Holder................Front/Rear bumper and covers......
'89 Chrome Grille.........Headlight brackets......................F/R Seats
'89 Painted Grille........Splash guards for engine/wheel wells/inner fender
ETC (A64-000-E00/31036 85E00)......ETC (ETC N26 F1)
ABS ECU (47850 86E00).....ECU (EB: A18-A45-E97)...ECU(73: A18-A13-E71)
Passive Seat Belt Units (x2) (28570 85E10 and 28570 85E00) *Hope the numbers help everyone match what they need.
Dash Trim:
Peice around guages....................Trim for switches (behind steering wheel)
Passenger's "A" pillar......................Dash cover (below steering wheel)
L/R Kick panels.............................Stereo console and trim cover
Glove box....................................Trim panel (around glove box)
Guage cover (black rings and clear plastic peice cover only)
Center console (x2)...................Center Conseole Lids (x4 black)
VG:
VG block.................VG heads (partially assembled).....VG exhuast manifolds
VG engine (Runs).......Flywheel............................. .....Stock Ign. Coil
Throw Out Bearing.....Stock air box and intake piping......Various Relays
Misc engine gaskets...ECU (#a18-a13-e71 <9114>)........Various electronics
..............................Piston Rings (new: VG/VGT)
VE: VE block............VE Heads.......................Lower intake manifold
ECU (automatic).......Auto Tranny w/torgue converter......5sp tranny
flex plate
VGET: Low intake manifold.............Fuel rail w/injectors (low ohm)
Valve Covers.............Stock T3 turbo (core only).............Flex plate
Misc. Aftermarket
*Random Tech Cat. Converter: 2.5" (922211) New in Box.
*New R33 Skyline tail lights.Straight from Nissan, mint condition.
*Autometer A/F guage and sensor.
*New Headlight Bulbs: 9007 (x3) and 9004 (x1) Blue bulbs. $5 per set.
Make offers! Many other peices as well, email for specific questions.
Old May 6, 2007 | 09:41 PM
JDNewberry's Avatar
Got a throttle position sensor?
Old May 7, 2007 | 07:35 PM
Get Off My Lawn
I do for a VG. Make offer.
Old May 11, 2007 | 02:32 PM
redwood_usa's Avatar
you have a vg iacv ? how much shipped to 75025
Old May 11, 2007 | 07:57 PM
Get Off My Lawn
I do have this part. Shipping from me to you is $9.00 via UPS. Make me a reasonable offer.
Old May 11, 2007 | 08:24 PM
Duckman540i's Avatar
VE Powah!!!
I really really need a front right ABS + LSD spindle. I don't need the hub, just the spindle. Do you have that?
Thanks!
Old May 11, 2007 | 08:38 PM
Get Off My Lawn
I believe so. I'll verify it is for a VE vs VG. Got a pic to make sure I'm thinking of the right thing?
The spindle is the central/rotating peice attached to the hub which the axle inserts into, correct? Aren't those pressed in/out of the hubs? Please clarify for me.
Old May 12, 2007 | 08:40 AM
nForce's Avatar
The Computer Guy
Do you have a ABS tower were all the brake lines attach to inside engine bay? Mine is leaking pretty badly
Old May 12, 2007 | 11:55 AM
You have PM
Old May 12, 2007 | 12:45 PM
nubiannupe's Avatar
OG Maxima.org Member
Dang, Chris... what'd ya do, jack the junkyard??
Old May 12, 2007 | 02:13 PM
VE Powah!!!
Yes it's exactly that. You do have to press them out, but if you couldn't, you could always ship the hub itself with the Spindle attached. It has to be off of an ABS car, and I believe off an LSD car as well. Anyone else know if this is true?
Thanks!
Old May 13, 2007 | 12:22 PM
Get Off My Lawn
Duckman: I sent you a mail before I checked the thread. Any spindle I have is bad. I wouldn't replace this part with used anyway...buy new. Remove hub and take in. Save you loads on labor.
Jimbo: YGM. Will await payment.
Nubi: I did find a lot of nice parts at the last JY run, perfect corner lights, chrome grille, and a cup holder I think will work on our cars. Otherwise, this is stuff I need to move out of my garage. I have shelves of nothing but Max parts, literally. Stuff listed is just things I figure people might need/be looking for. I've got tons of other stuff too (relays, AC pump, AC lines, switches, brake caliper brackets, etc).
Old May 13, 2007 | 08:55 PM
Maxpwer's Avatar
No turbo, no care!
Do you have a complete wiring harness for a VG? How much do you want for the VG block?
Old May 13, 2007 | 09:02 PM
Maxpwer's Avatar
No turbo, no care!
Thanks!
First. your terminology is messed up. The hub is the part that spins and holds the lug bolts. The spindle is the housing for this, and bolts to the strut and ball joint. If you have a bad/damaged hub, get a JY one as a new one runs $140. If you just have a bad bearing in there, it would probably be a better idea to press out and replace it with a new one. (something like $50).
LSD does not matter, it just needs to be a spindle off a DOHC with ABS.
Old May 16, 2007 | 06:45 AM
AllMaxxedOut's Avatar
Hey Chris,
Might be interested in the P/S pump & reservoir. Might also need other engine parts for VE but have to start tearing the engine down to see what else is needed.
If you wouldn’t mind giving me a quote shipped to 11434, then that would be great.
Thanks,
Keith
Old May 16, 2007 | 06:55 AM
maxine'sMan's Avatar
if you have injectors or coilpacks for a VE please PM me. I won't be checking this thread as these are for someone else.
Old May 16, 2007 | 06:38 PM
Get Off My Lawn
nforce: No ABS pump. Sold some time ago.
Maxpwr: First, thanks for clarification of components. Sometimes I feel like Tom Cruise in Days of Thunder...I know how to do the work myself, but don't always know the terminology. Second, no complete wiring harness. Have several peices for the engine harness such as for injectors and some cut plugs for sensors. As far as the VG block, make me an offer. Has about 200k miles on it. I pulled the engine because upgraded to turbo. Rings need to be replaced as it was starting to use oil. I have a brand new Nissan ring set to go with it if you're interested. Rings for a turbo, but shouldn't make a difference. Didn't use rings becuase I had to bore my turbo block which required larger pistons and rings.
Allmaxedout: YGM. BTW, thanks for making it easier on me and contacting me by my direct aol email account.
Maxine'sMan: No VE coils or injectors, sorry.
Old May 16, 2007 | 08:16 PM
traxtar944's Avatar
Would be lost w/out the org
have rear brake caliper brackets for 89-91?
Old May 17, 2007 | 07:17 PM
Get Off My Lawn
I'm sure I do, I've got several. Unless you have a picture of the difference, I'll have to pull my Chilton's and FSM to cross reference them.
Old Jul 1, 2007 | 08:03 PM
Get Off My Lawn
Still got lots to dish out. Any takers? I am willing to consider trades.
Old Jul 1, 2007 | 08:24 PM
bartown202's Avatar
What color are those trim pieces
particularly the left kick panel.
Old Jul 2, 2007 | 04:38 PM
traxtar944's Avatar
I'm still looking for one more rear caliper brackets for finishing up my BBK
Old Jul 2, 2007 | 07:29 PM
Get Off My Lawn
Bartown: All black.
Traxtar: Apologies, I never could obtain a picture comparison of the difference. Can you get me a pic to compare? Sorry, have a lot going on at work and won't get to take pics until July4th when I'm off. I've got brackets, just don't know what year.
Old Oct 28, 2007 | 04:16 PM
Get Off My Lawn
*Bump* List Updated. New parts added. Have additional armrest/lids for center console. Also have stereo trim and an extra set of cloth seats now (I upgraded to leather).
If anyone would be interested in trading, I'd consider. Right now I'm needing a rear passenger's side window regulator. I'm game for some Playstation Games as well. I have a PS3, so I'd entertain any prior system game.
Old Oct 28, 2007 | 06:38 PM
maxima-junky's Avatar
I have a rear pass side wndw reg I'll trade for any bs head unit with cd
Old Oct 29, 2007 | 09:06 AM
Get Off My Lawn
Sorry, I've got a couple "BS" headunits, including a double din Bose (CD and tape- 3rd Gen) and a JVC. The bose wouldn't work in the car I pulled it from or another max I put it in. Of course the car I took it out of, I installed another CD player and it worked in/out so there is a wiring issue on the car somewhere. The JVC "supposedly" works, but I have no plug/connector for it. I've never worried about trying to buy little pins in order to get it working and track down all the wires. I've also got an "el cheapo" amp. No plug there either but I did find wires that fit it and have run it, I know it works good. It says 200 watt, but I'd rate it at probable 50-100 watts total (2 channel: JDM "Japanese Dynamic Labs"). I know it pushed a 15 inch sub, but it did not "pound" by any means. Sorry can't help. Anything else interested in?
Old Oct 29, 2007 | 09:29 PM
twinkle's Avatar
got any vg injectors?
Old Oct 30, 2007 | 04:39 AM
Get Off My Lawn
Yes. They are still on my complete engine. But, no one has indicated interest in it and I think my wife's VG has a bad one or two. I'd be interested in pulling. I know they work becuase I started and ran the engine before pulling it. How many? Make me an offer plus shipping. You can email me directly at Mxmumpwr@aol.com.
Old Oct 30, 2007 | 07:05 AM
blackandwhite's Avatar
To them I'm like an idol
I emailed you yesterday about a VE ECU and some VTC electrical connectors, did you get it?
Old Oct 30, 2007 | 12:06 PM
crabapple's Avatar
I need the valve cover gaskets and the other gaskets that will be needed ( intake manifod, throttle body, EGR(?) ) when I remove everything to get to the valve covers.
Got any of these?
Old Oct 31, 2007 | 08:17 PM
Get Off My Lawn
Black and White: No email or Pm. Try Mxmumpwr@aol.com again. We'll have to match up the numbers off your ecu versus what I've got to ensure I've got what you need. We'll need to talk about exactly what you're referring to with "electrical connectors" so I can track down if I have it or not.
Crabapple: I know I've got about everything you just mentioned yet I will have to verify. Please give me till Friday evening to do so due to my work schedule.
Old Nov 1, 2007 | 11:08 AM
gen3fan's Avatar
Are the VE heads still available? If so- condition, price? Valves, cams, VTC's included? Thanks.
Old Nov 2, 2007 | 07:29 AM
Get Off My Lawn
Black/White: Still no email. I've listed ECU numbers in original post if you want to compare. I've got coil pack connectors and some that I know for sure. But, I need an image as a reference to differentiate from many other connectors I'm not so sure of.
Crabapple: Here are the gaskets I pulled together for you. I have the lower intake collector gasket (I do not have the upper intake collector gasket, you can actually use tubed silicon/gasket maker). I have both throttle body gaskets as well as the IAC Valve gasket if you want to remove it and clean it while you're at it. I also have both EGR gaskets. Sorry, NO valve cover gasekets. Make me an offer.
Gen3: I still have VE heads. They are about 50% dissassembled. No VTC's and the cams that connect to the VTC are gone, only the other set of cams are still installed. Rockers gone. Valves and springs still installed. Heads themselves are in great shape, just not complete or fully assembled.
Old Nov 6, 2007 | 08:46 AM
crabapple's Avatar
Thanks for checking that. I think I'll just get them all at once somewhere since you don't have a few that I need.
Old Nov 20, 2007 | 01:03 AM
helps
how much for the vg radiator?
Old Nov 20, 2007 | 03:07 AM
Will thosw Skiline tails fit a 92 se?
Old Nov 20, 2007 | 08:20 PM
Get Off My Lawn
Helps: Make me an offer. As I recall, the radiator does have a broken nipple at the top where one of the brackets secures it to the radiator support. It can be fixed. It does not leak and the fins are in good shape.
Max-junky: Yes/No. The skyline tails will fit only after body modifications to the rear are performed. I know of at least two 3rd gens with R-33 tails. There are other members who have modified other tails into their Maxima's. Here is a link to one such install.
http://forums.maxima.org/showthread.php?t=386767
Old Dec 3, 2007 | 08:03 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
any non-bose rear speakers? PM me if you do
Old Dec 4, 2007 | 12:52 AM
smitty124's Avatar
Whats the condition on the rear mandifold for the VE?
Old Dec 4, 2007 | 05:03 PM
Get Off My Lawn
Caped: No Non bose Max speakers. I do have some JBL's 5 1/4" or 6" and some other kind of 3 way 6x9's lying around. Nothing spectacular though.
Smitty: I'll have to check. I think I sold them and I don't see them listed above.
