why are my signals flickering sooooo fast?
Today I installed led 1156 bulbs for the signal lights, does anyone know why led bulbs make it flicker so fast? Will I get pulled over for this?
thats because they are LED.. leds use less current than regular bulbs do so the circuit that flashes ur turnsignals thinks that the bulb is out.. u need to put a 100 watt 6 ohm resistor in parralel with that bulb....
^^ dont know about all that. but all cars (i think) the turn signal goes really fast when one of the bulbs is out, just look at all your signals (front and back) and make sure they all work, happened to me a little while ago, just had to replace the bulb $3 from autozone.
I think I have a short somewhere in my right signal's. Most of the time it will flash normal, and sometimes it will randomly flash quick a bunch of times, then return back to normal again. Haven't gotten around to checking my connections yet. I thought I was tripping out the first few times it happened.
Originally Posted by LiGhtSoUt
bkmax98 its wat f550 said put an equailizer and ur good to go becareful where you mount it because it heats up
Edit: V = IR
P = IV = (I^2)R
live by it.
It's because they are leds as 550 said.
Or you can get a LED flasher relay and replace your stock one. As opposed to wiring a resistor. I replaced mine when I converted my tails and signals to LEDs. I'll try to dig up the relay part number...Or if Kevlo can chime in here. He supplied my flasher relay.
Is the flasher relay in our car the typical 3-prong type used in almost everything? If so you can get a heavy duty flasher/relay for towing at any auto-parts store and it will take care of that problem.
Originally Posted by f550maranello2
yeah alright, so it IS the standard type, just a fyi you can pick up a 'heavy duty flasher relay for towing' and that will do the trick as well, street-bike guys started running into this problem years ago when they'd put flush-mount blinkers on their bikes which had smaller bulbs=less current draw.
Originally Posted by bkmax98
thanks man, i hope i can figure out how to install this
foodmanry
Sep 24, 2015 12:02 PM
