recommended tire psi sux!!
Originally posted by bylss
i just pumped the tires up to the recommended cold tire psi and now i can feel every bump on the road! it used to be 4-5 psi lower for front and rear and the ride was a lot smoother and quieter. life's unfair!!
psi under arm rest
Originally posted by Max_Gator
let some air out - unless you had it ridiculously low in the first place. by the way - are you going by the placard on the door or the max tire pressure on the sidewall?
For all of you w/ Plus-Sized Rims....
A word of caution:
If you stepped up to larger wheels...
and consequently lower profile tires...
do NOT use the factory reccomended pressure...
unless you wanna BEND those pretty, expensive wheels...
To protect your investment:
Set the pressure to 5 psi less than Maximum Pressure.
For those who failed Math 101...
Lets say your maximum pressure is 44psi...
you set it at 39psi...
Follow this advice & avoid those pesky potholes!!
Re: For all of you w/ Plus-Sized Rims....
Originally posted by My 4DSC
A word of caution:
A word of caution:
thanx, and did this happen to you adam?
DC_Juggernaut
Sep 28, 2015 04:07 PM
