Sponsored by:
Sponsored by: CARiD
Wideband o2 Hookup.
Old Jun 13, 2007 | 04:02 PM
machinehead131's Avatar
Wideband o2 Hookup.
Alright guys, I am almost on my way to tuning. Headers are in and VAFC is wired up. Now my zt-2 came in today and was wondering which wires I need to hook up?
The intructions are located here - http://www.zeitronix.com/installatio...structions.pdf
Obvioulsy, power and ground - Do i splice them to the ECU harness in different areas than the VAFC...or can I hook them up elsewhere other than the harness.
Which other wires do i need to splice to the harness?
What pin number on the harness are these wires located to tap into?
Thanks guys.
Old Jun 13, 2007 | 05:30 PM
MikeSDA's Avatar
Are you replacing a factory sensor with this WB02 or are you welding in a new bung for it? If welding in a new bung the hook up should be very simple, power, ground, display wire...that should be about it. The power and ground can come from anywhere and the display wire goes to your display which will also probably need a power and ground. ( btw: both switched power)
I didnt read the pdf but both my PLX's are like this this pretty much applies to most any wb02 excpet maybe a datalogging one or more complicated one like a plx 500
EDIT: just read the PDF, yeah its a more complicated one, but this should get you started
Old Jun 13, 2007 | 06:01 PM
NmexMAX's Avatar
dot dot dot ...
The zt2 is datalogging capable, so you will need an RPM wire. I would tap into the VAFC RPM signal wire. I used power and GND from the cig lighter on my set-up.
Old Jun 13, 2007 | 06:13 PM
So to tune for now, all i need is to tap the RPM signal wire? power and ground. Nothing else on the harness?
Oh and BTW I am tuning with laptop, I do not have a display.
Old Jun 13, 2007 | 06:23 PM
NmexMAX's Avatar
dot dot dot ...
Not very familiar with the zt2, but try the instructions. They help.
Software seems user friendly. Plug into laptop, install program, view, verify parameters (AFR/RPM), log, WOT, view results.
Old Jun 14, 2007 | 11:51 AM
I did but I just wanted to see if I only needed to tap the RPM wire to tune my AFR. Theres like 10 wires on the harness so I wasn't sure. And I should be able to post some numbers up tonight.
Old Jun 14, 2007 | 01:56 PM
Did you guys drill a hole in the firewall or is there a spot to run the cable through that already exists. Passenger side.
Old Jun 14, 2007 | 05:06 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=506260
Firewall, next to the master cylinder. Grommet + RTV =
Old Jun 14, 2007 | 06:09 PM
Drivers side? Can you take a pic for me?
I need to get this in, I have power, ground, throttle, and RPM spliced/soldered.
I just need to route the wideband in cabin somehow.
Old Jun 14, 2007 | 06:23 PM
NmexMAX's Avatar
dot dot dot ...
Old Jun 15, 2007 | 02:20 AM
Looks like a possibility, any other suggestions?
Old Jun 15, 2007 | 06:39 AM
NmexMAX's Avatar
dot dot dot ...
Get under the car, there is an entry point just under the driver side seat IIRC.
Old Jun 15, 2007 | 08:12 AM
jmeister's Avatar
I know there is on the 4th gens, that's where I ran mine, but wasn't sure about the 5th gens
Old Jun 15, 2007 | 11:59 AM
Ill look for the seat thing,.
Old Jun 15, 2007 | 12:40 PM
matty's Avatar
I ran mine around the shifter....boot pulls out, and feed it through past the cover and out..
-matt
Old Jun 15, 2007 | 12:45 PM
-matt
Is there a rubber plug in the bottom for this?
Old Jun 15, 2007 | 12:49 PM
Bufflomike's Avatar
Sexier Than Simpson
If you are having trouble figuring out how to run the wire into your cabin, do you think this WB may be a bit of a leap for your skills?
Old Jun 15, 2007 | 02:54 PM
Thanks but no. I am just looking for the best/easiest option. I have installed headers back and pressed in bushing, brakes, audio, ect. by myself. I think if my mechanical ability is up to that then I am sure I can find a way, thanks for your concern though.
Thanks for contributing to the thread and answering my simple question.
Old Jun 15, 2007 | 03:58 PM
nismology's Avatar
Easy there, boys...
Old Jun 16, 2007 | 10:50 AM
Originally Posted by nismology
Easy there, boys...
Sorry, I am just looking for an easy way.
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
Slamrod
Sep 3, 2015 07:38 PM
BigDogJonx
Feb 28, 2005 04:10 PM
Jime
Nitrous
Sep 7, 2004 01:47 PM
