300ZX manifolds
300ZX manifolds
do you guys like what i made here?
tell me what yea think? these are direct bolt on to any maxima, just have to move the battery and get a different coolant tube under the intake manifold,and your all set to go.
just seeing if anyone was kind of interested in this or not?
I'm sure you did this but want to bring it up just in case... did you modify the left manifold (flange side) to allow exhaust to flow to the crossover pipe? I found out the hard way that they are completely separated and you have to cut quite a bit of metal out of the flange side to allow exhaust to flow to the crossover pipe. Looks good though!
okay, just seeing if anyone liked emm,
im not using them any more and im thinking of putting them in the for sale section. just seeing if anyone likes the way they look.
i made them fit by, putting them on and welding them
Originally Posted by goon9
Someone would buy them. I would but I had some na manifolds from a j30 that I'm going to rework.
... NA ... NA ! !!
GO TURBO
hahahahahahahaa!i have a down pipe and a waitse gate cross over pipe 2. ill pop up a pic or two next weekend when im home.
... NA ... NA ! !!
GO TURBO
hahahahahahahaa!
GO TURBO
...I was going to rework them for a turbo.
sure
Not sure if you think I'm full of ****, I'm pretty sure I carried out everything I said I was going to do...
Anyway. I still have yet test fit them on my motor, But I like that idea of the j30 ones being because they are tube and not cast.
cause i bought a VG30ET ... came with them and i worked with them from there to fit , just to get my motor running. but i want alot of boost, and im running a bigger turbo, so i changed to something bigger.
... you would want these to go TURBO
Apr 16, 2020 05:15 AM
