Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Clay bar didn't remove water spots
Old Jun 22, 2007 | 12:14 PM
bladerunr's Avatar
I used a Meguiars clay bar to try to remove some water spots on my paint but it didn't work very well. The paint is smooth but the water spots are still there. Any ideas on removing the water spots? thx
Old Jun 22, 2007 | 12:38 PM
BigFly_2K2SE's Avatar
Do you have a PC? If so, I would try a light abrasive polish and see if that works. Personally, I am partial to PBs and would try SSR1. If that doesn't do the trick, then I think your problem runs deeper than water spots.
You could probably do this by hand too although it would be A LOT more work.
Old Jun 22, 2007 | 04:21 PM
TheKrazyRaven's Avatar
4 8 15 16 23 42
yeah water spots arnt something that a clay bar will take out, you're going to need to use some sort of polish on it
if your gonna try by hand give Meguire's #9 Light Swirl Remover a try, you're gonna need to bust your *** to work it in without a Porter Cable though
Old Jun 26, 2007 | 11:18 AM
rsly33's Avatar
Try 50/50 water vinegar before anything. Removes waterspots that arent etched perfectly
Old Jun 26, 2007 | 02:13 PM
qbturbo's Avatar
I had the same problem. I used the Meguiar's clay bar w/the Quick Detailer, water spots faded, but were still there.
I had to use the Meguiar's 3-step system after the clay bar to get rid of the water spots:
(1)paint cleaner, (2) polish & (3) Carnuba Wax
No more water stains. If that doesn't work, the 50/50 water & vinegar solution is a method that was suggested too.
Good luck. Depending on your time and how much you want to spend, you might want to try the water and vinegar first.
16_SR
Sep 9, 2015 07:14 PM
Hdnseek
Sep 9, 2015 05:55 AM
Colossus
Sep 9, 2015 05:46 AM
