Car eating batteries
My brother in-law has an old 93 se that he rarely drives. About a month ago someone ripped his radio out. Since its a beater he hasn't been in a rush to replace the radio so the wires to the radio have been dangling in the dash board. His sister has been driving the car for the last 3 or so weeks and in that time its been through about 4 batteries. First the factory battery, then about 2 - 3 new batteries.
Somethings obviously wrong but we can't figure out what. Alternator checks out and the terminals are clean. Yesterday was my first time looking at the car and I noticed the wires to his radio so Im thinking that may be it, but don't know for sure.
Can anyone confirm this as the problem?
Capitone
Capitone
there is a fuse box on the left side of your battery(if your looking from the front of car) there are 3 main fuses in there check them. when my radio was ripped i had a bad fuse in there (100 amp) and it caused my alternator not to work although it was good
Depends how the radio was ripped out if the harness plug is gone it's possible one of the 2 power wires are shorting out. Maybe the insulation is ripped along the wire also if the radio was pulled out with force? Isn't their a fuse for the radio is so pull that since obviously this just started when the radio was stolen.
Mooze & Goon9...interesting tags, lol
Thanks for the feedback. I'll run a check through the fuses today. Am I looking for the alternator fuse or radio fuse? I'll check both if need be.
As for how I checked the alternator, we took it to autozone yesterday and got another new battery. Popped it in the car and headed back to have em check the alternator.
take all the exposed wires and tape them off separately from one another.
have you made sure the dome light is off and all the interior lights are off when you close the door?
I've never had a "fresh" battery go bad.
As far as the problem just starting since the theft, thats the thing. My inlaw didn't drive the car very much prior to the incident. He bought it for $200 bucks about 7 months ago and has probably driven it 6 times since then and even then never very far, just to the corner store or something.
Like you, I tried to get a feel of whether or not the problem was prexisting, but its hard to tell under the circumstances. His sister is the first to drive it since the purchase for longer than 10 or so minutes, and she did it after the theft so I dunno. Im inclined to think that it may be due to the radio seeing as the first battery was factory.....well thats what he said and he's no car nut like me. Could've just been an old battery for all we really know.
Does anyone think there may be a possible problem with the hot wire not being grounded though a radio? Should this be a concern too?
One thing about testing alternators. I have had alternators go bad on seveal vehicle ( i am a mechanic) and taken them into Autozone and other parts stores to have them tested. They checked out OK. Sometimes burned out diodes and other things can cause intermentent charge. I don't know how many times I have had an alternator test OK but it was bad. So if they test the alternator and it checks out and you have exhausted any other cause I would look at maybe replacing the alternator anyways.
Regarding alternator:
If you have a multimeter or voltmeter, check the voltage across the battery while the car is running. If the alternator works, you will get over 14V, if not it will be less. Bench tests are not always conclusive, but this will tell you if its performing its job.
Radio:
Doesnt seem related to the power drain. If there was a short, a fuse would blow and there would be no drain.
2-3 batteries so quickly is a lot obviously. If both the starter relay and the starter have problems, that could do it. Does it start well when you start the car, or do you have to try a few times?
If there is a slow drain in some system, you could pull all non-essential fuses and relays, and see if the battery lasts. Then add them one by one until the problem re-appears.
Radio:
Originally Posted by mooze
do all of your lights function ( dome, door, dash etc)
I DID note that the positive terminal is NOT factory…at least not when I compare it to my 97. My car has THREE wires connected to the positive terminal. 1 main connector for the positive wire and TWO wires attached to some sort of Red harness that is also attached to the connector via ONE metal piece coming out of the harness. I think I've read somewhere that one of these is for the starter or something. Looks like the aftermarket connector in his car doesn't provide any real space for the metal piece sticking out of the harness. Its currently sandwiched onto the aftermarket connector with the positive wire and wrapped in electrical tape. As far as I can tell, whatever it is, it should be making a good connection.
Originally Posted by 92 Max
How'd this person get into the car? Could they have bent the door frame or trunk frame enough to cause the courtesy light or trunk lite switch to stay on?
I think some of this new info points somewhere. I want to say charging, but I really thought the autozone test eliminated that as an issue. Maybe someone here sees something I don't.
Let me know,
Capitone
Don't they do that at autozone? I thought that was how they checked either the battery or alternator. Both parts were tested. Do we need to test it ourselves?
I think there are some circuit points in the alternator that they test for resistance and/or continuity, but they don’t actually hook it up to a belt and spin it.
Oh they did an in-car test? I thought it was removed.
Anyone have thoughts on how the positive battery terminal is rigged? The more I think about the more I feel that the test at autozone would have would have covered this too, so it appears Im back at square one.
If you want to go that route, these things are cheap, and easy to set up. You'll eliminate a potential resistance in the circuit, but it probably wont solve whatever electrical problem there is otherwise.
I would double check this terminal,make sure the connection is tight/clean,and as a precaution replace it with a better connector,they have higher end gold terminal connectors at most chain auto parts stores that have separate connection points for each wire..a little pricey (about $15) but it may be worth it..
Also,have you tried the old "disconnect the positive cable while it's running trick"?
If the car dies when it battery cable is disconnected,then a bad alty would be suspect...
worked for me
worked for me
Blah..I've done this test on dozens of cars in my lifetime,never hurt any of them..Of couse not saying it couldn't happen,just i have never seen it myself or heard of anyone personally causing any electrical failures from it..
But if you don't feel safe doing it,don't do it...
It depends on how much of a DC spike you expect to get. For small perturbations, the capacitors in the individual electronic parts will filter. The thing is though, if the alternator has a bad voltage regulator, you would see larger spikes.
I still think this a charging problem. If the alternator on this car is original, that multiplies that likelyhood by a gazillion %. Alternators are a component that is expected to fail at some point, thats why they are usually easy to get to.
Update:
Worked on the car yesterday. Pulled fuses, removed the positive terminal rig and sanded over the contact points to ensure a good connection and put it all back together, taped up all the loose radio wires and started the car on the new battery. As can be expected, it started right up no problems. Seeing as me and a few members here have been suspecting there is a charging a issue, I didn't think it hurt to drive to another auto parts store and get the alty checked again. This time we went to Advanced autoparts and had them check it….
Alternator IS toast. I chalk this one up to Murphy's law.
Lakersallday24
Jun 16, 2019 01:35 AM
doobadoo
Aug 15, 2015 06:43 PM
Superbform
Aug 11, 2015 08:10 PM
